01-05-2016, 10:51 PM | #31 |
Liked 100 Times in 45 Posts
Re: Resurrecting the Rambler
My gremlin had the 4 cylinder spring. Worked for me.
Thank you for the kind words. Sometimes I do miss the car.
Former NHRA #1945 Former IHRA #1945 T/SA Last edited by Ed Fernandez; 01-06-2016 at 08:44 PM. |
01-05-2016, 11:15 PM | #32 |
Liked 13 Times in 7 Posts
Ed, all the other guys I've talked with say you're a legend.
Brian Saunders Lerna IL '79 AMX T/SA 3790 currently being resurrected |
01-05-2016, 11:33 PM | #33 |
I did give it some consideration, but basically its the same thing as what I already have here in my red '82 . I planned from the very start to run a lower class like R,T, or U, and a V8 AMC car won't get there. The 304 V8 cross member in the car for sale would have to get changed out to a 6 cyl model one, necessitating the very same ordeal I'm going through now removing the 4 cyl one, and it had some other things done to it that I would want a little different. All in all, it was about a toss-up. Certainly nothing wrong with the seller's car as far as the build, if I hadn't had this spare '82 Spirit sitting here, I'd probably have went for it!
01-05-2016, 11:43 PM | #34 | |
While we're on the subject of springs and such, I have one shot of a nearly completed right side suspension.
01-05-2016, 11:54 PM | #35 |
Newly rebuilt right side suspension installed less brake pieces. Amazing what some freshening up, wire wheel clean-up and some semi-gloss black paint can do. The engine cross member is in place now and the car will roll again.
Next time the auto shop bay is empty on a weekend, the left side gets the treatment.
01-06-2016, 12:22 AM | #36 | |
Liked 182 Times in 62 Posts
FWIW my current springs in my car are original 78 Mercury Zephyr 4 cyl springs from a previous car with over 100,000 miles that I had a 351 C in. Those same springs have been in my Mustang since 1998. As long as your springs have not been heated I cannot image them being a problem. There is nothing better than the sense of accomplishment on you building your own car, it may not be cheaper, but you will know every nut bolt and wire in the car. Think about adding front tie downs into the front crossmember. It will make loading and unloading the car faster and more secure too! Sean
Sean Marconette 84 Mustang 5060 SS/N Last edited by Sean Marconette; 01-06-2016 at 12:26 AM. |
01-06-2016, 01:03 AM | #37 |
Thanks for your info Sean. It's not so much that I was afraid of spring fatigue or wear, the right side one was a handful with the spring compressor getting it out and back in, but more so that they might not end up transferring the weight changes on the front end on a launch in a fashion to really help me any. For now though, they have to stay there whether they're close to optimum or not.
On your tie-down idea, not sure other than welding loops or tabs onto the cross member how you mean to do this. And could this constitute "modifying the frame" in the rulebook sense? Don't need any surprises at first tech session.
01-06-2016, 08:29 AM | #38 |
Liked 233 Times in 124 Posts
Good luck and have fun.
Speaking of frame modifications and what's legal; this may not be; from post #26: "I had to leave the 4 cyl original coil springs in place for now until I get something figured out, may see about a re-work on my spare upper A-arms I have from the '80 car to move the spring perches inward at some later time." Others would know better than me, it's hard to tell what's okay these days. |
01-06-2016, 11:01 AM | #39 | |
Liked 8 Times in 7 Posts
without losers,winning means nothing. |
01-06-2016, 11:09 AM | #40 | |
btw, i'm using 6cyl springs but it's a trunion car...
without losers,winning means nothing. Last edited by Tom keedle; 01-06-2016 at 07:09 PM. |
