Old 12-02-2011, 04:21 PM   #31
duke66
Default Re: Tech West Racing Services MSD Upgrade
This is Cad's Dad. Is there an upgrade available for the 6AL? What are the sparkplug wires that you recommend? This is a 12 to 1, 383 SBC. What wire electrode sparkplug would you recommend.
Thanks,
Duke
duke66 is offline   Reply With Quote
Old 12-04-2011, 11:33 AM   #32
lareagle
Liked 26 Times in 12 Posts
HI Paul
MSD 7al2 can you build timing retard inside box?
Thanks
Larry
lareagle is offline   Reply With Quote
Old 12-04-2011, 03:33 PM   #33
duke66
How many volts input will a 6AL stand? I know your Maxpwer 20 is 20 volts. Will a 6AL stand 24 volts input?
Old 01-26-2012, 04:33 AM   #34
GTX JOHN
Liked 2,490 Times in 700 Posts
Pat:
We run HVC Blue Coil on MSD 6AL on a couple of our Low Compression
Small Block Stockers.......would we be happier with one of you recommended
Coils? They sure are less money on initial purchase.
Thanks,
John Irving
Old 02-22-2012, 10:51 AM   #35
Reed Granrt
I had a customer to ask me a question, yesterday and I had no good answer. He asked which is better of the 6AL MSD units., a reworked analog(Tech West unit) or the new electronic digital MSD 6AL.
reed
Reed Granrt is offline   Reply With Quote
Old 02-23-2012, 10:49 AM   #36
Reed Granrt
Originally Posted by Techwest Racing Services View Post
Reed Granrt
Short answer, currently an upgraded analog 6al will out perform both stock boxes from Texas. The advantage a Digital has is a little smoother Soft Touch Rev limiter than the analog version from the testing we have done with in house customers. That being said we are working on an upgrade package for the Digital box that should take the box to another level as well. We have multiple in house testers that have been running the Digital box in tandem with an upgraded box. They all have come back with their staying with analog box until we have the Digital box package ready to roll out later this year. I hope this answer your question, if not you know where to find me!
I have had both types on my dyno with a scope hooked to both and everything I could look at here said that the analog box was better also, but my equipment to check is limited and I did not want to give a false answer.
Thanks for the reassurance
reed.
Old 02-24-2012, 01:01 AM   #37
Reed Granrt
Reed
Easier to ask then explain a wrong answer! Been there done that......:-) Have a good one & try to stay out of Trouble!!!!!!
I tried staying out of trouble one time, and it wus no fun at all
reed
Old 03-01-2012, 07:40 PM   #38
Anthony Fetch
Hey Pat I just wanted to let you know I shipped my msd 7al2 and according to the tracking it was left at the front door. If you can just confirm that you have recieved it. You can reach me on my cell 732 966 7731
Thanks
Anthony Fetch
Anthony Fetch is offline   Reply With Quote
Old 03-02-2012, 09:12 AM   #39
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Hi Pat
I have stumbled on a Tech release Addendum quoting that the PN 7530T ( among others) will " shut Down unexpectantly" if a resister is not added to the "power on" line while using 16 volt battery's if the hand held PN 7550 Monitor is left hooked up..It states that if your unit has R1 or R2 stamped on the end panel,updates are already installed and this resister is not needed. Mine is stamped R4. I'm taking it that this is revision 4, and the other ones noted were revision 1 and 2...But wanted to verify. Thanks for you time and info, Jeff
Jeff Niceswanger 3740 SS
Old 03-12-2012, 11:59 AM   #40
Chad Rhodes
Pat, wondering if you could give me a hand with an ignition noise related issue?
Chad Rhodes 2113 I/SA
