View Poll Results: Fuel injection? Do you run in open loop or closed loop
Open Loop 80 65.04%
Closed Loop 43 34.96%
Voters: 123. You may not vote on this poll
Old 07-16-2012, 04:06 PM   #31
KRatcliff
Liked 534 Times in 143 Posts
Default Re: Fuel injection? Open or Closed loop?
Which sensor?
KRatcliff is offline   Reply With Quote
Old 07-16-2012, 05:02 PM   #32
Ed Wright
Ed Wright's Avatar
Kyle, he has to be talking about the IAT sensor.
Usually mounted in the air filter box or ducting. Can also be screwed into the intake manifold and set up as a MAT sensor. Lots of race cars running around without one, the diagnostic code shut off, and the correction table zeroed out. In Speed Density mode, most recommend a MAT sensor being used.
Ed Wright 4156 SS/JA
Old 07-16-2012, 05:20 PM   #33
KRatcliff
Gotcha. I wasn't sure if he was referring to the MAP sensor which is in the proper position for Speed Density, but flipped up and the hole plugged for Alpha N.
Old 07-17-2012, 01:44 PM   #34
Capri
Liked 27 Times in 14 Posts
Intake air temp sensor. For me, its a factory unit screwed into the lower intake. Just noticed alot of others let it flap in the breeze near the entrance to the TB. Just wondered if it helps something in the fuel curve control.
Capri is offline   Reply With Quote
Old 07-17-2012, 01:55 PM   #35
KRatcliff
Yes, it can help. If you see it out in the open air, like in front of the throttle body, then they are generally running it in Alpha N. Ed's post covered it pretty well.
Edited to add: I do use the air temp to affect my fuel curve to a small degree.
Old 07-17-2012, 06:55 PM   #36
art leong
I have mine screwed into the air box near the scoop. Works fine.
Art Leong 2095 SS
Old 07-17-2012, 09:22 PM   #37
Capri
Art,
What I am wondering is if I plug the hole in the intake, and just leave it out in the open air, if it would change anything. Its not a problem or anything, but just a thing that makes ya go hmmmmmmmmm
Tony
Old 07-17-2012, 09:26 PM   #38
Ed Wright
Ed Wright's Avatar
I wouldn't bother moving it.
Old 07-17-2012, 09:30 PM   #39
art leong
Art,
Tony
Mine is in the open air of the box I built around my throttle bodies. This picture was taken before I finished it The sensor is in the sheet metal.
Art Leong 2095 SS
Old 07-18-2012, 11:23 PM   #40
Marine One
Marine One's Avatar
If you are concerned that the ambient temps are causing the ECM to pull timing, just adjust / eliminate the amount of timing being pulled via the AIT mapping.
Chad Sheets | STK 319 | 10.69 | 1.39
Marine One is offline   Reply With Quote
