Old 12-03-2024, 10:22 AM   #21
Woodfin
Liked 286 Times in 108 Posts
Default Re: Square 10
You are correct; many levels are the correct number.
Old 12-04-2024, 03:06 PM   #22
Woodfin
more bars
ID:	71788   Click image for larger version
ID:	71789   Click image for larger version
Old 12-07-2024, 11:28 PM   #23
Woodfin
a few mockups
ID:	71810   Click image for larger version
ID:	71811   Click image for larger version
ID:	71813   Click image for larger version
Old 12-13-2024, 08:59 PM   #24
Woodfin
Because I am calling this my Square-10 build, I am making things square when possible. Am even considering having a carpenter's square design logo displayed in some way.
ID:	71823   Click image for larger version
ID:	71824   Click image for larger version
ID:	71826   Click image for larger version
Old 12-21-2024, 06:45 PM   #25
Woodfin
Artwork comes in many forms. High-rise shifter mount for the square 10 made from square tubing and a test of possible color
ID:	71846   Click image for larger version
ID:	71847   Click image for larger version
Old 12-23-2024, 09:27 PM   #26
Woodfin
The square 10 will be a bare bone, stripped down, light as possible hot rod.
ID:	71861   Click image for larger version
Old 12-24-2024, 08:43 AM   #27
Frank Castros
Liked 2,732 Times in 964 Posts
Nice work!
Build is for what class?
Old 12-24-2024, 05:43 PM   #28
Woodfin
Frank, Thank you. It is a simple, basic, bracket toy for local tracks. It will run about a 6.30 ET with a 383 SBC.
Old 01-12-2025, 07:42 PM   #29
Woodfin
Switching over to engine assembly and related components. the firewall forward to mostly ready for paint.
ID:	71893   Click image for larger version
Old 01-13-2025, 08:01 PM   #30
Woodfin
Around twenty years ago, I considered replacing my old sealed power manual ring grinder with an electric model. Each time I would consider doing so, I would convince myself I would only do a few more engines, so I would get by with what I have. Well, now I am age 77, and it is a slow, tedious, time-consuming task with the old manual tool. But I will only be doing a few more engines. Old fellows, old tools, old ways that define me. I average about 45 minutes per cylinder to gap rings, assemble the rod to the piston, work with the pin clips, and install the piston and torque rod. Then, a break to look things over, ponder, daydream, and perform other necessary duties. So, it is really an hour per cylinder. And this is with everything already clean, already checked, and everything laid out.
Also note my 50 year old ring squaring tool.
Larry Woodfin
ID:	71895   Click image for larger version
