#21 |
Liked 52 Times in 32 Posts
So.....without a regulated pressure switch, when you turn engine off, doesn't the pressurized oil in accumulator pump back to the oil pan? If so, no pre-oiling at start up, (how important this is, is debatable) would happen as the accumulator is empty.
SC 707Y |
#22 |
Liked 529 Times in 36 Posts
Without a switch or manual valve the oil pressure will bleed off. Not having a switch to me is a waste of time as it defeats the purpose.
Darcy Clarke A/SA SS/EA |
#23 |
I think the pre-lube feature is a secondary feature to the accumulator. I would guess most are utilizing it's capabilities as a safeguard against oil starvation.
Todd Greene |
#24 | |
Liked 125 Times in 59 Posts
I run the electric valve on mine but I don't run the pressure switch. ![]() |
