Old 08-28-2020, 07:28 PM   #21
west coast
Liked 230 Times in 75 Posts
Default Re: Wire Shielding EMI or RF Noise?
Ok finally got to look at both data loggers samples, The fast system sample is .05 seconds and my tach samples at .01 seconds. I know i can export my fast system to excel, i will check to see if i can export my tachfact software to excel also and the overlay a same run to see what is looks like. My tach down loads look much smoother then the fast system, I could be it is filtered some?
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 08-29-2020, 05:54 PM   #22
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,390 Times in 506 Posts
Yes I believe the tachfacts is being filtered and you are correct is it actually a better sample rate than the FAST. Mine does look better on tachfact but definitely not as nice as the super stocker looks on there. I went overboard with wire shield and ferrite cores so I will see what happens.
'65 Mustang SS/L & L/SA
