Old 04-25-2020, 08:32 PM   #1
rod
Liked 20 Times in 15 Posts
Default stock class rear axle?
I am considering stock class racing my 56 Chevy, [again] after many years. does the rule book still say you have to run a corporate rear axle? I do ,not want a 12 bolt.
can I use a '55-'64 style center with different bearing ends and race axles? also can the tubes be shortened[just a little]?
thanks Rod min AZ
rod is offline   Reply With Quote
Old 04-26-2020, 05:09 AM   #2
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Default Re: stock class rear axle?
thanks Rod min AZ
Yes and No
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 04-26-2020, 12:52 PM   #3
Lyn Smith
Liked 1,002 Times in 203 Posts
Rod, you could use a 57 -64 Pontiac/ Olds rearend housing if you wanted to retain the stock look. It is not legal to make the stock rearend narrower plus the tires will be up against the springs if you do. A cheaper alternative is finding a 8.5 out of a Camaro or Firebird. Just as strong as a 12 bolt, but not as many ratio options.
Lyn Smith is online now   Reply With Quote
Old 04-26-2020, 01:18 PM   #4
Wink Re: stock class rear axle?
Better reconsider the 12 bolt ,with Pro gears, if it's going to be a stick car.
Pontiac/ Olds not legal in Stock
Old 04-27-2020, 07:48 AM   #5
e vassar
Liked 281 Times in 110 Posts
X2 What Mark said
Old 04-27-2020, 11:19 AM   #6
XSTOCKER
XSTOCKER's Avatar
Liked 8 Times in 3 Posts
The Olds/Pontiac rear is not acceptable for a Stocker trifive......I asked.
XSTOCKER is offline   Reply With Quote
