Old 05-21-2019, 05:44 PM   #21
carl hinkson
Liked 18 Times in 10 Posts
Default Re: Oil bypass, do you block it?
Originally Posted by Rich Biebel View Post
If you look in a Wix filter book it lists everything as far as specs but doesn't say anything about how a filter is mounted
Numerous engines mount the filter other then straight up and down...….and everytime you start it oil pressure takes longer to build up as it fills the filter that drained back.
Never gave it much thought myself until I read the catalog.....
Physical size, thread size, with or without the anti drain back feature....probably more info but I don't have a catalog handy...
I did go look at a 51060 and a 51061 just to be sure I had the info correct...
Those are std length filters....
They also make a shorter length and a 2 quart "truck" filter.....
Some are labeled Extended Life....
I use the 51061 R on my engines and have for years.....Bought them by the case...
We buy from Filter One.....Nobody comes close to their prices and they ship UPS...
Only issue is they do a very poor job boxing filters for shipment.....Some get damaged or boxes busted up.....occasionally....
I don't use the R=filters they have a 51 Micron rating the 1061 have a 21 Micron rating
carl hinkson is offline   Reply With Quote
