Liked 223 Times in 73 Posts
I recently locked out the advance in my distributor. I took the car out for testing with my backup engine last night and while the engine has some issues, the distributor worked out fine, and I had no trouble cranking when hot. But the timing did wander back and forth a couple of degrees, and when I put it in I could feel the rotor moving back and forth just a little.
I'm pulling the distributor out anyway to swap back to my good engine now and I'm thinking of putting a little tack weld between the plates to prevent any movement at all. There's no electronics in this, just the magnetic pickup. I don't think that would be bothered by one second of arc. What do you guys think, good idea, bad idea? Any drawbacks other than the obvious increased difficulty in restoring centrifugal advance later on? |
Liked 99 Times in 60 Posts
Dave,
another option is to drill through both the fixed and movable plate and install a roll pin. Doing so gives the option to go both ways.
Larry Woodfin 471W |
Liked 310 Times in 174 Posts
That's a good suggestion by Larry. If you decide to put a small shot of weld on instead, take out the pick up and cover the sensitive areas with tin shield or pull out the shaft. Always place your ground cable as close to the weld area as possible and put the weld where it could easily be removed with a thin grinder wheel.
Liked 165 Times in 59 Posts
the timing wander could also be caused by the timing chain and or the gear lash on the cam/distributor
Liked 239 Times in 114 Posts
Two things come to mind . First , if you tack weld the plates ,t will be very hard to index the distributor cap . It would be better to drill a hole through both plates then file a slot in one , so you can move the reluctor around to get the timing and the cap index correct . Second is to shim the shaft to get minimum endplay on the gear .
