#21 |
Napier style second rings help with oil control, and require less oil ring tension. Using a fish scale to measure drag, I've been down to 4.5lb drag, but got some blue smoke at times. 6 lbs seems to run just as fast, with no blue smoke. 4" bore.
Ed Wright 4156 SS/JA |
#22 |
Liked 264 Times in 69 Posts
Adger, I'm interested too. maxwedgejohn@aol.com
John Dinkel 3295 STK |
#23 |
Liked 169 Times in 53 Posts
If you're trying to get by cheap, just use correct size moly filled top ring with shim stock behind it to space ring close to edge fo ring land on piston. Use next undersize plain iron 2nd ring as is. Use next undersize oil ring expander with correct size oil rails. This works pretty good for cheap ring package on sbc.
Bill Bogues 4696 STK |
#24 |
Liked 154 Times in 37 Posts
123
66W30POST Last edited by Dan Lattimore; 03-08-2019 at 02:24 PM. |
