#21 |
May I ask the part number of the Valvoline oil you refer to?
I have used the VV850 in the past but they no longer offer it. I believe they changed the formulation. Do you use an additive with the oil? ______________________________________ Andy Stone A/S 1102 SS/C 1112 |
#22 |
Liked 7 Times in 6 Posts
The oil I used is straight 30 racing oil. It used to be commonly called VV223 but the Valvoline part number is 822401. Scroll down a little to find Valvoline's conventional oil part numbers, https://www.valvoline.com/our-produc...vr1-racing-oil
I don't use any oil additives. |
#23 |
Liked 759 Times in 379 Posts
don't use either.
Been running Mobil 1 Synthetic 10w-30 in my race engines for nearly 3 decades. This past season switched to Lucas Synthetic. Have a case of Maxima Synthetic that I will run this season. |
#24 | |
Liked 799 Times in 236 Posts
The oil deal is a bigger issue for Stockers that have to use a flat tappet camshaft combined with high spring pressures and aggressive lobe profiles. For those not running under that set of rule constraints, there are dozens of oils that will work well. Excessive additive precipitation is something to consider when choosing an oil filter. Those dots can be connected accordingly. ![]()
"That'll never work....." |
#25 | |
Liked 138 Times in 51 Posts
Valvoline says that straight weight oils are usually recommended for smaller and older engines. 5th question down: https://www.valvoline.com/about-us/f...-viscosity-faq
LOCOMOTION Racing |
#26 |
Liked 1,900 Times in 570 Posts
I had really good luck with the full synthetic Valvoline racing oil. Cant seem to find it anymore at the local parts stores.
Mike Pearson 2485 SS |
#27 |
Liked 316 Times in 67 Posts
I've been really happy with JR-1
You may want to look at Reher-Morrision tech tips on oil and filters, oit of 100 tips they are toward the end (95 & up as I recall) Filter tip very interesting One thing they told me was to try Bad *** oil, I believe the originator of the early good Royal Purple. FWIW |
#28 | |
Liked 70 Times in 31 Posts
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#29 |
Liked 1,535 Times in 572 Posts
There is a racing oil brand that has been recommended to me by Nick Ferri.
It's manufactured in the USA by HPL Superior Lubricants. Nick shared with me that it is the oil he has been using for some time; it makes power and protects the engine. I believe Bo Butner is also using HPL Racing Oils too. https://www.hploil.com/ |
#30 |
For a tough heads up, mine is just a few hundredths quicker on Royal Purple "race 9", which is, IIRC, zero-10wt? Pours like water.
A friend in the lab at the Sunoco refinery here locally tested some oils for myself & a couple of racer/friends. The highest load before gaulding the ball on the load tester was 10W30 Valvoline VR1. I had used Penzoil for years, since they furnished my oil for a few years ago. When the free oil ended, I felt like I owed it to them to start buying it. Tested well also. The VR1 handled more load than anything. RP was very close. They tested what I could find. Pennzoil tested well too. VR1 tested best. I am not claiming to know everything about this. Only what friends tested for us. Your results may vary.
Ed Wright 4156 SS/JA |
