Old 11-05-2018, 11:38 AM   #21
Mike Mans
Liked 299 Times in 48 Posts
Default Re: Man. trans for Stock
Hey Don - Which Liberty 5-speed trans are you running? Any idea what that trans weighs alone?
Mike Mans is offline   Reply With Quote
Old 11-05-2018, 03:18 PM   #22
Mike Jones
Liked 684 Times in 289 Posts
Originally Posted by Don Anderson View Post
Liberty Gear 5-speed with the Long shifter.
They will get you the trans ratios you need for your combo.
"Man. trans for Stock"
...4 speed only
Old 11-05-2018, 03:41 PM   #23
Mike Mans
You can run a 5 speed manual in stock if the vehicle came from the factory with a 5 or 6 speed manual. It just has to be clutch assisted, not clutchless in design.
Old 11-06-2018, 07:52 AM   #24
Mike Jones
Thanks Mike,
I don`t know why, but I assumed Tony was running 1st gen Camaro.
Old 11-06-2018, 11:24 AM   #25
Mike Mans
Thanks Mike,
Sorry Mike, I was just clarifying for Don Anderson's example - I wasn't thinking about Tony's original post question. Don runs an 80's Fox body that is eligible for a 5-speed where you're completely accurate that Tony (presumably in a '67-69 Chevy) can only run a 4-speed.
Hope that wasn't too confusing!
Old 11-06-2018, 09:01 PM   #26
Don Anderson
Liked 24 Times in 8 Posts
Talking Re: Man. trans for Stock
Mike,
Aluminum case & tail housing goes about 100 lbs.
Magnesium case & tail housing are 8 lbs. lighter.
I had Paul @ Liberty Gears help me upgrade an old Doug-Nash 4+1 back in 2008 to Liberty`s face plate system legal for my 1985 M/S NHRA Stock Mustang and up-grade the shift shaft seals in the case. I know for Super Stock racer Terry Johnson who went to Liberty`s 5-speed and picked up .2 in his car and made it more fun to drive again.
Don Anderson is offline   Reply With Quote
Old 11-07-2018, 12:17 PM   #27
Mike Mans
Mike,
You're right, the 5-speed Liberty Equalizer was a pretty substantial gain for the small motors vs. a traditional Jerico 4-speed. I just weighed our G-Force 4-speed with aluminum case and it was like 97lbs with shifter and everything. Similar.
Old 12-04-2018, 10:17 PM   #28
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
is jerico still in business ?
Old 12-05-2018, 02:30 PM   #29
t.tosto
Liked 62 Times in 23 Posts
They are still doing business but didn't seem too interested in drag racing trans. business at last years PRI show. Will check this year to see if anything has changed, at least hope in so far as to provide replacement parts. Tony Tosto
t.tosto is offline   Reply With Quote
Old 12-05-2018, 07:46 PM   #30
gmonde
gmonde's Avatar
I called them today ,,I have a dr-4 wide gear trans and looking to see if they still support parts ,, the response was they only support the dr-4 revision 4 only ,I have to get back with them with my serial number ,, how can I tell if is a revision 4?
