Old 10-05-2018, 05:47 PM   #21
Dave Gantz
Liked 251 Times in 125 Posts
Default Re: NHRA amended rollbar / cage rule
Good question.
What makes an 11.50 bracket car safer than a 12.85 Stock Eliminator car?
I agree. Probably incompetence on NHRA's part.
I'm sure the bottom line is a matter of following the money trail.
My 87 Mustang street car needs a roll bar if the air is good. (11.40's) I don't want the seat belt hassle, so no roll bar, and I only go when the air is bad. I have no problem with a roll bar and race belts, but just let me use them (race belts) for more than 2 years! I hardly ever run it.
But, I digress. I can't help myself when I see these roll bar threads.
Old 10-05-2018, 06:56 PM   #22
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Why not just slow your car down a tenth or so instead of just racing in bad air ? Carry an extra 100 lbs in the trunk, short shift it, install a throttle limiter like when S/G came into nhra's program back in the stone age ?
Old 10-05-2018, 07:13 PM   #23
Chevy55
Banned
Liked 179 Times in 89 Posts
Why won't the NHRA rewrite the rule so they're not legally responsible for the seat belt like NASCAR?
Chevy55 is offline   Reply With Quote
Old 10-05-2018, 07:26 PM   #24
Keith 944
Keith 944's Avatar
Exactly! What I do with my street/strip car is disconnect the back carb barrels. slows it about 1/2 sec. or i carry weight, and can also adjust timing, easy peasy! Some use one of the mechanical stops. whatever gets the job done. like many, I just don't want to put a roll bar in a pristine 67 dodge coronet that is still occasionally driven on the street
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-05-2018, 08:14 PM   #25
Bruce Fulper
Liked 54 Times in 33 Posts
NHRA: "We REALLY don't mind if you get injured." ...............or worse.
Bruce Fulper is offline   Reply With Quote
Old 10-06-2018, 01:09 PM   #26
Dave Gantz
I'm guessing you're saying that with tongue in cheek, but I'll address it anyway.
I have a few more things I'd like to do to the car. It's a toy, and I like getting what I can out of it. It'll probably go low 11's with what I want to do. I've always understood that there has to be a line (et) somewhere where a roll bar is required, and I'll eventually do the roll bar. But now, because a car is quick from the factory, it's safer than mine?
Old 10-06-2018, 01:32 PM   #27
X-TECH MAN
Banned
Cool Re: NHRA amended rollbar / cage rule
It does not matter to me if something goes wrong and a tire blows, or the engine oils down the tires and it goes on its roof. Hang on to the steering wheel ! As far as any of this new junk being safer..........NOPE. Not a bit when you hit the wall at around 100 MPH plus.
Old 10-06-2018, 04:24 PM   #28
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: NHRA amended rollbar / cage rule
Drive a U/sa and all you need is a helmet.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 10-06-2018, 05:29 PM   #29
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Yep.
When I ran 11.80's in N/SA 4 years ago a helmet was all that I needed and my 28 year old seat belts
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 10-06-2018, 07:57 PM   #30
Coleydog
Liked 53 Times in 38 Posts
A roll "bar" is nothing more than a suppliant to the car, whitch the car is considered a cage of sorts. If being highly safe, a funny car roll cage is your only option, the rest is a money grab, pure and simple.
Fighter jets go longer than two years on belts, mostly after 6-10 gs I think.
The dumbest, blow shield re-inspection, 1/4 inch steel goes bad I guess.
