#21 |
Liked 20 Times in 15 Posts
FYI, the waterless coolant is basically RV anti-feeze. it will not cool unless you used a 20 lb or higher rad. cap. most rads. will not take that kind of pressure. I use that RV AF in my solar hot water system. believe me, it absorbs a lot of heat. but getting rid of the heat using the RV AF is not easy
Rod in AZ |
#22 | |
Liked 70 Times in 31 Posts
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#23 |
Liked 126 Times in 20 Posts
mix in a gallon of windshield washer fluid
Tim Worner SS 1747 |
#24 |
Liked 431 Times in 224 Posts
I like to keep a couple gallons of antifreeze in the system.
S/ST 51 S/C 53 |
#25 |
Liked 8,208 Times in 1,536 Posts
#26 |
Liked 133 Times in 76 Posts
#27 |
been using coolant for years with no concerns but don't forget about Evans Coolant they also post contingency
#28 |
We used a Prestone product with pure tap water that was a rust inhibitor and water pump lubricant that worked pretty good. Haven't been able to find it as of late, Prestone may have quit making it. All cooling systems believe it or not will have a small amount of electricity running through it so, you have a small amount of electrolysis taking place feeding on the engine block and causing the water to rust up. We have been using the Red Line product, Water Wetter as of late. It seems to work pretty well.
Nelson Kowal Stock 345 |
