Old 09-15-2017, 10:46 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default 8 3/4 and a 4spd
'64 Dart 273-2V 4 spd- will a 8 3/4 rear hold up? If braced? Thanks
House of Darts is offline   Reply With Quote
Old 09-16-2017, 01:27 AM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: 8 3/4 and a 4spd
i am interested in this too
Old 09-16-2017, 02:41 AM   #3
Rod Greene
Liked 242 Times in 81 Posts
After you do all the mods to make the 8 3/4 live you will realize you could have done a Dana. A well built Dana will be within 15 lbs of an 8 3/4 and has less parasitic loss and you will never break it.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 09-16-2017, 09:42 AM   #4
randy wilson
Liked 22 Times in 22 Posts
But, to your original question, it will hold up just fine.
don,t have one
Old 09-16-2017, 09:53 AM   #5
Dragsinger
Liked 99 Times in 60 Posts
The Chrysler 8 3/4 is a good piece. There was a time it was found under many drag race cars, even the Don Hardy Vega conversions.
Because you are building a relatively low power package I think the 8 3/4 is the best choice. In addition, assemble it with very little pre-load on all bearings. Basically, just take the slack out. When assembled, it should be very easy to rotate.
Considering your engine choice, ANYTHING that reduces rotating drag will be of value.
Larry Woodfin 471W
Old 09-16-2017, 10:57 AM   #6
House of Darts
Do I limit myself to 4.88 gears due to the taper and the harsh launch of the 4 spd?
Old 09-16-2017, 12:30 PM   #7
Rod Greene
That is why a Dana is a better choice. Economics, Durability and Drag. A Dana can be built for virtually the same money, it will never break and it is worth ET. Seems like a no brainer, but that is just me.
Old 09-16-2017, 01:52 PM   #8
GTX JOHN
Liked 2,509 Times in 701 Posts
I agree with Rod ......... I have never had great success with a 4 speed and
slicks with even a good 8 3/4. Now that we run two steps we are eliminating them from about everything. I have broken several 8 3/4s
before two steps even in our 318 O/SA ( Even with Pro Gears and braced
Housings ). The cost difference is not very much between the two alternatives.
John Irving
741 Stock
741 Super Stock
