Old 03-28-2017, 11:18 AM   #21
M Brand 505B
Liked 31 Times in 10 Posts
Default Re: Metric 200 question
You need an ultra bell if you want the cracking issue to go away for good. Even with the brace the factory bell will still crack.
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 03-28-2017, 11:21 AM   #22
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Would you use the brace with an ultra bell?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 03-28-2017, 11:29 AM   #23
Jim Kaekel
Liked 535 Times in 110 Posts
Originally Posted by PozQB14 View Post
Where/when will you notice the failure? I put new gears in the car just so I can move it. I started the car up and just went forward and reverse to put it in the garage and nothing seemed out of whack. Ill definitely drop the pan, would I feel a difference in higher gears?
I wouldn't bother running it. Drop the trans pan and you'll probably find evidence of a torn-up rear sprag with small pieces of rollers and springs in the pan. Common event when you tear the rear out.
Jim Kaekel 3836 STK
Old 03-28-2017, 12:05 PM   #24
j gardiner
Liked 55 Times in 29 Posts
If it was a violent break on the starting line you definitely better look. I have broken one 350 and one 200 planetary that way.
j gardiner is offline   Reply With Quote
Old 03-28-2017, 12:12 PM   #25
Liked 5,145 Times in 1,964 Posts
You probably won't be able to tell if the low/rev sprag is on the way out , that way.
It needs to be inspected physically , at least annually, in my opinion
High maintenance item on the 200.
If anyone knows of an upgraded unit, I'm listening.
Old 03-28-2017, 12:21 PM   #26
PozQB14
Liked 42 Times in 17 Posts
Its weird. car launched great, wheels came up way higher than normal. 330' time was the best ever, then BANG! gears were lost. pulled over as fast as a I could to the wall, checked for leaks, towed to the pits in neutral.
PozQB14 is offline   Reply With Quote
Old 03-28-2017, 12:23 PM   #27
PozQB14
BTW, I use a brace with my metric and have zero issues. you wont need one with an ultra bell.
Old 03-28-2017, 03:17 PM   #28
Darrel Goheen
Where can you buy the brace? Thanks.
Old 03-28-2017, 04:09 PM   #29
PozQB14
Pm sent
Old 05-23-2017, 09:01 AM   #30
A Levreault
Liked 15 Times in 5 Posts
What kind of performance gain can someone expect by going from 2:74 low gear to a 2:91 in a 74 Camaro running stock eliminator with a 350 and weighing 3740lbs.
A Levreault is offline   Reply With Quote
