Old 03-05-2016, 12:18 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default oil pump help
433 BBC bracket/index car. I want to switch from my HV pump to a standard volume to pick up a few hp. I have a Moroso 22150 pump that I bought in '09 and never used. I called Larry Stewart but he isn't making pumps until he can find a suitable machinist. I've also thought about a Schumann with an external bypass return. I don't think I need a billet, but I'd like to hear your thoughts on which way to go?
Ron Gusack is offline   Reply With Quote
Old 03-05-2016, 01:10 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: oil pump help
Ron,
You only need enough volume to overcome the required flow of your clearances.
This Melling might be a good choice for you: 10774
10774Standard volume performance upgrade for M-77.
The housing and cover are CNC machined and phosphate coated.
The lower pressure spring is included to reduce pressure if desired.
Includes intermediate shaft with steel guide.
Uses 3/4” press in screen.
Adger Smith (Former SS)
Old 03-05-2016, 05:45 PM   #3
Ron Gusack
Ron Gusack's Avatar
My current pump uses the cap as the pickup and returns the bypass oil to the pan, which has always seemed like a good thing to me. That Melling doesn't look like it has the grooves in the cap and wall of the body. Is anti cavitation over rated? Somewhere around here I have detailed info on how to drill the cap to get the bypass oil straight back to the pan, but I haven't been able to find it. Is it not necessary?
Old 03-06-2016, 09:57 AM   #4
Signman
Liked 269 Times in 99 Posts
Ron PM sent
Old 03-06-2016, 11:11 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,985 Times in 598 Posts
Go with billet. I had a cast iron pump shear off at the base. No more passenger type pumps for me. Worth the little extra money.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 03-06-2016, 11:57 AM   #6
Liked 1,925 Times in 432 Posts
I switched to Clay Valley Racing pumps. The last Schumann pumps I bought did not look nearly as good as they once did, which saddens me, as they had a really nice product for a reasonable price.
Old 03-06-2016, 12:12 PM   #7
Jim Hanig
Liked 99 Times in 49 Posts
Mike what do you think caused the shaft to break? I have raced chevys for 50 + years and never had a melling, chevy pump fail. Jim Blair does low pressure pumps Pierre s.d.
