#21 |
I know you can't believe everything you see on the net. Makes sense though, what the HO package would be in the year before the four barrel 302 came out.
http://auto.howstuffworks.com/1982-1...d-mustang1.htm
#22 | |
67 Ford Fairlane F/SA 749 |
#23 |
Liked 1,104 Times in 302 Posts
Similar, but not the same. The 82 2 barrel HO used a smaller air cleaner housing than the 83 thru 85 4 barrel models. Also, the lid of the air cleaner was basically flat on the 4 barrels, while the 2 barrel lid had a tapered dome. Both versions did have 2 snorkels, which were connected via plastic ridged tubing, to a plastic duct under each inner fender , that was directed behind the bumper rebar. I have ran my 85 Mustang with and without the air cleaner and ducting, didn`t seem to make any differance. I think any benefit from the fresh air was offset by the large aluminum air cleaner housing trapping the heat from the intake manifold, and heating up the float bowls.
#24 | |
#25 |
Liked 7 Times in 5 Posts
nhraracer.com has put out a notice today that the 82 model GT is stick only and has released pistons specs also.
Roland |
#26 |
Liked 4 Times in 4 Posts
Glad I quit when I did! I wonder who complained?
Joe Toller Lewistown, MT |
#27 |
Liked 370 Times in 101 Posts
Piston specs are for 2011-2014 302 engine.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#28 |
Too much talk about it on Class Racer
#29 |
Nice, a guy has to almost keep everything a secret to run a car. What's the point in helping others out or building a car if you can't trust someone will take it out from under you?
#30 | |
(ps), Obviously my first sentence does not apply to cars 2008 and newer!
