Old 09-11-2014, 06:59 PM   #21
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: 2000 Ford F250 Diesel air cond problems
With pneumatic actuators we apply pressure, and with a pressure above what is above the actuators spring pressure it will move. In this case its vacuum, but the same principal. With the 17-21" w.c. rating of the vacuum pump, the actuator should stroke to the full position, and remain there. With what you are describing chances are if you apply 17-21" of vacuum directly to the actuator, if it moves and stays fully stroked, it is fine. Work backwards from there until you find what is damaged or unhooked. It could be as simple as the vacuum line is disconnected or cracked at the actuator.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 09-11-2014, 08:33 PM   #22
FED 387
Liked 336 Times in 183 Posts
Sean-- thanx got my Sat AM all set up for doing this--Regards FED 387
Old 09-17-2014, 04:34 PM   #23
FED 387
Wink Re: 2000 Ford F250 Diesel air cond problems
OK --found it!!!! the insulatution they put around the battery over time had worn a TINY !!!!!! pin hole in the seam of the vacuum reservoir cannister--- even under water it rarely bubbled--- so I siliconed it for now but I have a BRAND NEW cannister coming--- the one we used that we thought was good had an even smaller leak but it did leak---
Thanx to all that rfesponded--- FED 387
