#21 | |
Liked 373 Times in 131 Posts
That electric fan and w.p. setup should be good for at least 5 h.p....probably closer to 10 hp. That's .1 sec off your e.t. right there. As Charlie ( 7423) stated above, the Tweecer allows many adjustments and is a simple plug-n-play setup. Their site: http://www.tweecer.com/
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#22 |
Using those programs, can you change from mass air to speed density and is there any performance benefits? or repeatability?
67 Ford Fairlane F/SA 749 |
#23 |
Liked 2 Times in 2 Posts
Got to the 1/8 track Tues. without a rainout. The car dropped about .03 and picked up 1 MPH with the elec. fan setup. Did a best time ever 8.7019 with 77.18 mph. I tryed the timming @ 15, 16, 17, btdc with out any real change. I don't have a weather station , everyone said there cars were slower. What do you think for the the next change , more gear, MSD box , adjustable fuel reg. stock elem. cam ?
Slickfoot 3955 |
#24 |
Liked 70 Times in 29 Posts
Do you know anyone that has a set of 26" slicks you could borrow to try? That would go a long way to show you how much a gear change would help your car.
If you spend the money for a stocker cam along with valve springs and good lifters, your RPM range is only going to go higher. Your 3:90 gear will become even more of a problem. A fast stocker 5.0 is going to run 7000+ rpm. You need to gear the car according.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#25 |
Last nights best 8.64 with 78mph 1/8 mile, air was 2500 ft. only changes were removed the screen from T/body and took out 20 more lbs. Still can't get to the 1/4 mile track test and tune gets rained out ever week.
By the way that a good idia about the test with a 28'' tire Slickfoot |
#26 |
what rpm are you launching w/ that converter?
Alex Cummings Newb |
#27 |
2500 rpm
Slickfoot |
#28 | |
#29 |
I'm thinking of going with 5.13s I know it's alot of gear for my stock motor, but that's the gear i'll end up with when I build a motor over the winter. Might be able to put a stocker cam and springs in it to get it to run to the end of the 1/4 with 5.13s for the rest of the year.
Slickfoot |
#30 |
Rained out again !
What MSD box and tack should I order for this build? Slickfoot 3955 |
