Old 10-18-2013, 10:29 AM   #21
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: questions about low 1st gear
Todd, just to clarify for the op, Leigh did not change the rear gear to calm the launch/kill the wheelie, he changed the rear gear ratio to reduce his trap RPM which increase by 200 when he made the switch to radial slicks 4 years ago, a gear ratio he had been running for nearly 30 years.
Old 10-18-2013, 11:40 AM   #22
Todd Hoven
Guest
Posts: n/a
Ed, I didn't / wasn't going to state the reason for the gear change. Just was relaying the results.
Old 10-18-2013, 11:52 AM   #23
hardtimes
couple of questions for todd & 1320racer about the mustang
- when he went to the 4.86 i take it he had a 5.13 in there before just curious how much difference that made in how the car left.
- you say he runs a 30x10.5 radial slick taht he went to 4 years ago, was curious what tire he ran before and how much ET did he pick up when he made the switch
- if my cousin keeps his 4.33 but goes to a 2.75 1st gear that would be the same as a 2.46 1st and a 4.86 rear. would that make a big difference, how would that affect the converter.
hardtimes is offline   Reply With Quote
Old 10-18-2013, 04:00 PM   #24
1320racer
1320racer's Avatar
The rear gear was changed early this season, so he hasn't run in the good fall air yet. At this point the wheelies are slightly less.
As to the tire, previously he ran 29 x 11 bias slicks. The radial slicks were worth less than a tenth, ~ .07.
Old 10-18-2013, 09:05 PM   #25
pintojoe II
The 4.33 and 2.75 would give you a slr of 11.91...The 4.86 and 2.46 slr is 11.96
pintojoe II is offline   Reply With Quote
Old 01-31-2016, 09:49 PM   #26
hardtimes
1320racer you said your friends Mustang ran 6.60's in the 1/8th was just curious with those 4.86 and 30 radials what kind of RPM is it turning at the stripe in the 1/8th
Old 02-01-2016, 07:59 AM   #27
Liked 10,852 Times in 2,254 Posts
Is the car 50/50 or better?
Old 02-01-2016, 09:13 AM   #28
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
The 4L60E gives heavy cars like my ImpalaSS a great 60ft time.
Car uses the heavier Locking Converter works good for 1-2 Shift.
First Gear is 3.09
D
Old 02-01-2016, 12:12 PM   #29
hardtimes
Larry the car is 53/47
Old 02-01-2016, 01:55 PM   #30
A 3% swing will make a big change. That is a summer of a little here and a little there. It's real cheep and it works. You can always add weight to make it 50/50, but its more fun to watch the car improve with a little bit of work.
