Old 10-07-2013, 02:34 PM   #1
Slickfoot
Liked 2 Times in 2 Posts
Red face 85 5.0 Mustangs
What makes the 85 Fox body 5.0 combo so good, that it hold 7 stock records. And why no SA records ?
and where are the 88,89,90s fuel injected Mustangs ?
Slickfoot is offline   Reply With Quote
Old 10-07-2013, 03:12 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: 85 5.0 Mustangs
Hey Rory,,, you may want to jump in here and enlighten this gentleman regarding this combo,,,my 2 cents.
Danny Durham
Old 10-07-2013, 03:25 PM   #3
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
Default Re: 85 5.0 Mustangs
Slickfoot, 1985 was the last year of the carburated 5.0 Mustang. It used a Holley 4-barrel carb and are stick only. The automatic version was fuel injected.
Travis Miller is offline   Reply With Quote
Old 10-07-2013, 03:31 PM   #4
west coast
Liked 230 Times in 75 Posts
Gary Summers makes this combo look easy, if it was easy everbody would be doing it. Looks like alot of hard work and testing that he does, my hats off to him. Wish my car was that fast. I dont think it is just a stick thing put a good C4 in it, it would still fly. The later fox bodys are easy to get under the index say .5 -.6 undar, but bad *** fast is all cubic dollars on a dyno and parts. Just like any other combo.
west coast is offline   Reply With Quote
Old 10-07-2013, 05:12 PM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
The 83-84 non- hydraulic roller is lumped in with the 85. It's apples and oranges. And its not anywhere close to .5 -.6 under with good parts and a lot of testing. I should have listened to Alex D several years ago. The 83 turbo 2.3 stick is a competitive combo, not sure of the 83-84 CFI 5.0 auto combo being competitive.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 10-07-2013, 05:33 PM   #6
Nick Heath
Liked 576 Times in 137 Posts
Sean
Sean, I think west coast was referring to the 87-93 combination being a good, cheap combination. You may never be low qualifier, but getting one to run .50-.60 under is very doable on a reasonable budget. We might even be able to call it a dime rocket!
I think the '85 is a good combination also. There have been a handful of them over the years in Stock and SS, and I think that all of them have run well.
Old 10-07-2013, 07:03 PM   #7
Slickfoot
What is a good combo for an 89 stick car , like I said it's been 43years for me . and what do you mean by dime rocket
Old 10-07-2013, 09:03 PM   #8
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Sean
^^ Marty Buth does well with the 83-84 Mustang 2.3 Turbo. ( Auto trans tho)
83-84 CFI 5.0 automatics are way over factored. Too high for that tiny CFI throttle body.
1985 4 bbl Mustang 5.0 combo had the hydraulic roller cam and the heads were better than the 83-84 4 bbl Mustang.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 10-07-2013, 10:54 PM   #9
Sean Marconette
Mark Walton ran the 2.3 stick combo in both a T-Bird and an 83 Mustang and set a few records.
The 83-85 heads, intakes and carbs are all the same except for casting numbers.
As for the author of this thread, everyone is here to help.
What trans and clutch are you going to run? Sorry if I derailed your post.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 10-08-2013, 11:59 AM   #10
Rory McNeil
Like Sean said, the 85 4 barrel heads are esentially the same as the 83-84 heads, in fact the same D8 heads were used on 302 2 barrel from 78 until Ford stopped making them. The only change for the 85s E5 casting was to add a clearance notch to allow the removal of the taller hyd. roller lifters without needing to remove the heads.
As for running a stick trans, I would not waste my time with a stock T5. When I first started running my 85 Mustang, I too thought it would be much cheaper than buying a good trans, by the end of that first year, I had 2 broken T5s, and a bent mainshaft that was replaced1/2 way thru the season. I put a Jerico and McLeod Soft Lok clutch in the car in 2004, and other than changing the trans oil occassionly, I have not touched the trans since. Same thing with the rearend, the stock Traction Lock and axles are not up to the task with a stick, although the axles would likely live with an automatic, the Trac Lock will let you down, and NHRA mandates aftermarket axles with a spool. Best to get some good pieces from the start.
NHRA 6390 STK
M/S 85 Mustang
