Old 10-09-2013, 01:21 AM   #21
MoonlightGraham
Default Re: exhaust cross over (heat riser) fill
Originally Posted by Mike Taylor 3601 View Post
Ron,
I use zinc alloy get from Mc Master Carr supply ,it's the same thing Mondello use to sell.
I melt enough into a steel cup I made from tubing and flat bar w/flat bar long enough to also be handle to pick up and pour with,I usaully block @ intake side and pour from bowl side have to use some sort of funnel some times.
The zinc will probaly out last the heads.
Mike Taylor 3601
Sorry to bring up an old thread but I was wondering how much zinc you needed to do this procedure?
This is what I found on McMaster-Carr's website:
http://www.mcmaster.com/#zinc-alloys/=outleo
Great info guys! Thank you
MoonlightGraham is offline   Reply With Quote
Old 10-09-2013, 08:17 AM   #22
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 317 Times in 108 Posts
I usaully buy the 4 1/2 lbs. bar 9069K2. depending on what type of heads you are working sbc can do 2-3 sets.
Have also filled intakes that are cracked in heat cross over area,just fill it up does'nt matter then.
Mike Taylor 3601
Old 10-09-2013, 08:37 AM   #23
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Interesting... I used the exact same Zinc material/part # from McMaster (9069K2) and when I pulled the heads after about 50 passes, I found the material melted back pretty bad in the port area.
Granted, I know it says it melts at 792°F, but I saw others using it with success, and figured there would be enough heat transfer into the head casting to keep it from melting...
Was going to use Aluminum next time (melting point ~1,220°F)....
No one else has melted the Zinc ???
Old 10-09-2013, 12:03 PM   #24
MoonlightGraham
Mike Taylor 3601
Thank you for the information
Old 10-10-2013, 08:41 AM   #25
Mike Taylor 3601
I have'nt had any problems that I know of with it melting out of head,I will tearing into one that was done about 200 passes ago will let you know how it looks.
I wonder how consistent melting point is? I have noticed some of the bars seem to melt easier,but I could just be less patient that day.
Mike Taylor 3601
