#21 |
Liked 2,493 Times in 700 Posts
My problems above mentioned were with the new smiths lifters..... my friend just destroyed his 340 engine last week with the punk coming off and busting his cam with another brand new set of Smiths. These things are expensive junk with a nonexistant warrantee, built by people who could care less about your problems. This has not changed over the years no matter what name is on their business!!! John Irving 741 Stk/SS
#22 |
Liked 5,147 Times in 1,964 Posts
They should have never been allowed in the first place. They are WAY outside of the intent of Stock rules.
Back in the day of Greg X and Marty Barrett, can you imagine if you took a stock lifter and machined off the bottom and replaced it with a ceramic puck? You and your parts would have been bounced out of the barn so fast , you would have been hit in the a** with a broom on the way out.
#23 |
Liked 510 Times in 117 Posts
68 Chevy11 327 F/S Last edited by Bob Gullett; 04-23-2013 at 12:36 AM. |
#24 | |
Liked 4 Times in 4 Posts
Bob, No matter what you post here someone will hijack the thread for their own personal reasons.....postings seem to take on a life of their own. JimR
Jim Rountree |
#25 |
Liked 57 Times in 33 Posts
Most of the problems people are having with the Schubek lifters breaking are the same that the guys who break roller lifters have. NOT ENOUGH SPRING PRESSURE. (everything bounces then breaks)
Duane Eiskant 1354 Stock/Super Stock |
#26 |
Bob Gullet,
I have his number at my shop. I have been a dealer of the SM lifters since 2007. If you call me at my shop, I can give you his contact info. Like B&B said, I have had no reported problems with SMITHS Lifters. I have sold over 75 sets since 2007. I have never had a problem getting in touch with Bob. I just talked to him last week when I ordered another set. He said that he was sick for a couple of weeks, maybe that is why he was hard to get in touch with. Not doubting what GTX John or some other people posted(anything is possible and everyone has made a mistake), but you have to have everything else set up for these lifters for them to work. Also, there were many problems with the original shubecks, but the SM lifters are different. Jeff Day #3731 |
#27 |
Liked 508 Times in 92 Posts
I was at Indy's tear down barn in 2004, this was right after the Pro Stock cars were told no exoctic material allowed in the motors. So I asked the tech director why was exoctic materials were allowed in Stock Eliminator's engines and he quizzed me on what I was talking about. So I told him that about the Schubeck lifters and that they are made of an exoctice material. Also I told him that you can't buy them in any ordinary dealership or auto parts store. Boy did that open up a can of worms with some of the racers in the barn.
Casey Miles 248H |
#28 |
Liked 719 Times in 220 Posts
I knew somebody with a 220 horse 283.He ran 90-100 on the seats, and this thing used to break rocker studs.He did it enough that we wondered what went on here. Valvetrain separation caused it caused by the low spring pressures. I bought a set of Smiths lifters two years ago,and am just getting ready to use them with a steel billet Bullet cam, 7/16" rocker studs,Elgin rockers, and was fixing to set the springs at 200 on the seats,400 over the nose. Floating the valves smacks the base into the cam lobe, and the resultant impact shatters it. They don't seem to like mechanical lifter camshafts,either,and the same thing happens. I don't think there would be a problem in the event of rocker arm or push rod breakage, since the lifter would be up and out of the way in a hurry. Is there a better lifter to use with this steel camshaft,or are Smiths the thing to use?I like the idea of being able to change cams without breaking in a set of lifters each time. Any responses?
#29 |
Liked 1,914 Times in 429 Posts
I'm not aware of any steel lifter that you can move from camshaft to camshaft without having the lifters refaced and polished. At this point, I'm not really satisfied with the DLC coating as it is applied to lifters, either. NASCAR teams have a nearly unlimited budget, and they still have problems with the coating coming off of their lifters on a somewhat regular basis.
Alan Roehrich 212A G/S |
#30 |
Liked 880 Times in 311 Posts
Coat the cam and shine the lifters. DLC is abrasive I think it spins the lifter better when the cam is coated. Esp. when more taper is ground on the cam and the lifters are crowned to match.
.02 for free....
Adger Smith (Former SS) Last edited by Adger Smith; 11-23-2009 at 08:55 PM. Reason: sp |
