#11 |
Liked 115 Times in 35 Posts
#12 |
Liked 48 Times in 24 Posts
Beg to differ there MR. Wong . No 2bbl is a good alt. car in my opinion.
And that 2bbl is tiny.How do iknow?lol
Rocketmancoatings |
#13 |
But that is Definately the nicest looking U/S ever.
Rocketmancoatings |
#14 | |
Liked 5,109 Times in 1,947 Posts
#15 |
Liked 419 Times in 85 Posts
I can go further under on the mountain with a stick 2 bbl than I can at sea level. The flywheel and RPM are the equalizer. At 164 hp its not 302 ford good but a good combination.
#16 | |
Liked 351 Times in 120 Posts
I was told that some of cars with the high HP combo had two control arms? Watch the tire slow mo and you will see when he shifts to second.
Tom Meyer 5240 SS Stock ??? |
#17 |
[QUOTE=Greg Reimer 7376;713937]Alright, having been through several 409 powered cars, the logical questions come to mind: 1. What did you do about the rear suspension with the single upper trailing arm that liked to tear loose from the frame at the front?
2. What rear axle assembly is in the car? A 12 bolt comes to mind here. 3. What gear ratio? 4.How about the drive shaft? 5. What is the total weight of this car with driver? 6.How much fun is it to drive? Looks like a real hoot. 7. What is the quickest and fastest time to date? So Greg ,i am replying only because i have intimate knowledge of those 409s.In 1964 I owned a black 64SS 409-425-4spd.-4:11 posi. I was 19yrs. old. So to address ea. issue from Greg which it sounds like he knows. But the rest of you might find interesting.1. All 64s had the 3 link.and a 10bolt.Including mine. Its what Jenkins used as a model to build some of his first prostocks. Designed to offset the engines rotational torque. 2 orig.10bolt. 65 was first 4link and 12bolt. And i saw no one ripping the trailing arm ,because ? we only had 7inch slicks.OMG leaving at about 4500 and slipping the clutch ,tires spinning -grab 2nd it 's still crabbing sideways untill you hit 3rd. A handfull on the street. Most awesome car i ever owned. See the actual car in my photo album.Raced it 1 time.13flat and one 12.95 i think. won my class but that was it. I was just learning and some kid was not going to beat the older guys. My payment was 62 a Mo.
Rocketmancoatings |
#18 | |
Liked 409 Times in 113 Posts
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC |
#19 | |
Liked 1,428 Times in 296 Posts
1) NHRA hp factor 2) Paul Wong has a lot of altitude 2 bbl stocker runs under his belt. He knows
James Schaechter 3163 STK |
#20 |
Liked 200 Times in 62 Posts
