Old 08-13-2024, 10:01 PM   #11
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: 10-ounce CO2 refill
Turbo Action Cheetah and the trans is a Metric T-200 reverse pattern V-Body
Biondo makes the air shifter add on and Digital Delay makes the controller
It's not legal for Stock but is working fine just for bracket racing for now.
It would be legal for Super Stock
Rich Biebel
S/C 1479
Stock 147R
Old 08-15-2024, 06:17 PM   #12
Pauley
Liked 223 Times in 41 Posts
I got a 20# bottle that i get filled at welding supply place. I put 10 oz bottle in cooler for a bit then hook up bottles and fill. Never weigh. No problems.
I just recently bought a car with kr compressor and Ed is right. It is the way to go. But my camaro has a bottle for now.
ep
Pauley is offline   Reply With Quote
Old 08-15-2024, 07:18 PM   #13
Jeff Stout
Liked 704 Times in 281 Posts
I fill the c02 the same way as nitrous bottles. Freeze bottle and I have a connector made. Make the connection and I think the little bottles hold. 10ounces. And usually get 8 ounces
Old 08-15-2024, 11:11 PM   #14
Mike Merk
Mike Merk's Avatar
Liked 82 Times in 24 Posts
I have basically the exact same setup - T350, Cheetah (forward pattern), Biondo solenoid, Digital Delay controller & adjustable regulator. If the pressure is below ~110 it shifts 1st to 3rd, if the pressure is 125 or above it shifts positively each gear change. In between it "hangs" on the 1 - 2 shift & slows the 330' time. The Biondo solenoid instructions align with what I've experienced regarding the 1 to 3 change stating that if this happens, increase the pressure.
I was asking all of this because I thought about switching to a K&R compressor, but if it only adjusts up to 100 PSI I'm not sure it will work for me.
Mike Merk
Mike Merk is online now   Reply With Quote
Old 08-17-2024, 03:21 PM   #15
Rich Biebel
I had similar issues with the Biondo shifting 1-3 if pressure gets to low.
The K&R pressure switch shuts off at 110lbs and does not go on until 90 or below.
I looked to see if there was a higher pressure switch I might be able to swap in but there was nothing that I felt was the right off and back on switch,pressure wise
Mines been working fine at 100-110 lbs and I just make sure the pressure is up before a run.....
I replaced my shift cable and the shifter is much easier to shift and I have not been out racing to check both the trans and the shifting issues I've been having.
Racing takes a back seat anymore.....
Rich Biebel
S/C 1479
Stock 147R
Old 08-18-2024, 10:52 AM   #16
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Pauley...KNOWS!
