Old 07-22-2024, 09:13 AM   #11
Billy Nees
Liked 7,782 Times in 1,743 Posts
Default Re: Metric T-200 issue
Richie, add 1/2 qt. of fluid!
Billy Nees 1188 STK, SS
Old 07-22-2024, 01:06 PM   #12
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
The lag is somewhat inherent in some valve bodies but many times its due to improper fluid level .
Here's the link to the Turbo Action tech tip on proper dip stick measurement.
https://www.turboaction.com/TH200Full_Mark1-04.pdf
Old 07-22-2024, 05:24 PM   #13
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I’ve been working on the car all day
Ran it for a few minutes and checked the level and it was low
It has a custom locking dipstick and someone marked it on one side for correct level
Without pulling the pan I can’t confirm that dipstick is correct
I’ll recheck it hot at the track next week.
Car needs some TLC and we’re getting reacquainted.
Rich Biebel
S/C 1479
Stock 147R
Old 07-22-2024, 08:08 PM   #14
Rich Biebel
Originally Posted by Angelo DiTocco View Post
Do you have a trans cooler? or a loop
No cooler and No loop.....plugged at the trans.....Don't know if that could be an issue....
Rich Biebel
S/C 1479
Stock 147R
Old 07-22-2024, 09:13 PM   #15
Adger Smith
Liked 880 Times in 311 Posts
Rich,
I don't know about a 200 but in a PG if you just plug the cooler lines off with out modifying the pump it causes a restriction in fluid flow out of the converter. Converter will function different with the restricted flow. Just Put a loop on it and see if it helps the issue.
Adger Smith (Former SS)
Old 07-23-2024, 06:06 AM   #16
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Metric T-200 issue
Good morning Rich and to all,
Rich I think you might want to contact the transmission's builder. None of us know who's front pump is in there, and what's been done internally. My McClay 200 is plugged. I believe Leon plugs his cooler inlet and outlet as well. If I remember correctly the Remac front pumps are made to have the cooler lines plugged. But there are other builders out there and some have a different way of getting the same things done. This is where you might want to get in touch with the original builder. If you haven't reached out to Mark Yac. now might be a good time. I'm not personally well versed on all the internal workings of those units to let you know exactly "what " to be looking for.
Have a good day.
Respectfully,
Henry Kunz 1534 H/SA
P.S. Rich have you put a pressure gauge on the trans and run it in gear, even on jack stands ?
Henrys Toy is offline   Reply With Quote
Old 07-27-2024, 08:59 PM   #17
Rich Biebel
Red face Re: Metric T-200 issue
Adding fluid did not help
2-3 flare is really excessive and is clearly visible on both the recall tach and datalog from the ECU
I will do more investigation this week to verify the fluid level and the shifter, cable and detent adjustments but I think this trans needs to be gone thru by someone that does them and knows what their doing
Like I said earlier, the men doing them are few and far between....
Rich Biebel
S/C 1479
Stock 147R
Old 07-28-2024, 07:02 PM   #18
SS3860
Liked 165 Times in 56 Posts
Rich, I run a metric 200 built by Thomas Arnett. It has the deep cast aluminum pan and takes 8 quarts to fill with the correct dip stick and tube. Cooler lines are plugged also.
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
Old 07-28-2024, 07:34 PM   #19
Tim Barrett
Liked 472 Times in 72 Posts
I had a similar issue several years ago with my Sepanic Metric 200. It was suggested that I shift it into 3rd gear and pull the shifter linkage pin out of the lever on the transmission. When I did I couldn't get the pin back into the lever. I had adjusted the shifter linkage with the transmission in park,,not in 3rd gear. Linkage adjustment is more critical for 1st 2nd and 3rd gear,,especially in 3rd. Never had slippage again going into 3rd.
Glad to see you back!!
Tim Barrett is offline   Reply With Quote
Old 07-29-2024, 08:07 AM   #20
Rich Biebel
Tim, that check is going to happen this week.
I did have the shifter all apart 3 times to change the gate plate and I’m using an air shifter just for bracket racing on an 1/8 mile
That’s just temporary as I know it’s not legal for Stock
I adjusted the cable up top but didn’t do the check at the trans.
I’m going to drop the pan as well as do that check.
At some point I’ll show up and run Stock again.
Maybe the Dutch, thanks
Rich Biebel
S/C 1479
Stock 147R
