Liked 759 Times in 379 Posts
Say what you want but my shifter made thousands of shifts unlike the shifter in a stocker
#2 | |
Liked 6 Times in 6 Posts
Your friend chose poorly, I would never use that shifter but many do.
#4 | |
Liked 183 Times in 48 Posts
I found that if you just hit the lever with your palm or finger--like a slap stick shifter--it'll go right into 2nd gear and not skip to 3rd.
SS/BS 1921 |
#5 | |
Guest
Posts: n/a
What is the proper method for accurate adjustment?
The primary check is for full travel from park to the opposite end of the shift pattern. Then verifying that all forward gear positions are in a relaxed condition is recommended. From PPP FAQs |
Liked 800 Times in 237 Posts
Had this exact problem with one I worked on. PPP showed less than z-e-r-o interest...never returned multiple calls, emails, etc. Tossed the junk original spring and sourced some spring stock from McMaster Carr. After a bit of tinkering with spring length and preload...problem solved. -Al
"That'll never work....." |
#8 | |
![]() ![]() I also considered the M&M and Motion Raceworks shifters which are available for both 2 and 3 speed trans, both very nice and made in the USA. Last edited by 1320racer; 07-10-2024 at 01:19 PM. |
