Old 02-10-2023, 12:00 AM   #11
Rory McNeil
Default Re: Fuel line, what's the best?
Originally Posted by Dave Gantz View Post
I use aluminum. It's light, easy to shape, and cheaper than braided. That said, I use braided for vibration connections.
Same here, my bracket car has the same Moroso aluminum fuel tubing that I installed 35 years ago, never had an issue with it. Important to have it secured properly, I have rubber lined mounting Adel clamps every 10-12 inches.
NHRA 6390 STK
M/S 85 Mustang
Old 04-21-2024, 04:32 PM   #12
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Anyone ever try the Russel twist lok rubber hose? https://www.summitracing.com/parts/rus-634163
J.T. Rose & Associates U/SA T/SA 302R
Rose Racing is offline   Reply With Quote
Old 04-22-2024, 10:22 AM   #13
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
I just replaced SS braided line that was in service for 20 years without issue. I’m now using black nylon braided Lines.
Old 04-22-2024, 11:08 AM   #14
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I've gone to PTFE lined braided hose for all fuel lines and transmission lines.
It will outlast any rubber type hose and will generally handle higher pressures and temps than typical rubber type braided hose.
I particularly like it for injection systems that are running 50 -90 psi.
Old 04-22-2024, 11:32 AM   #15
1320racer
1320racer's Avatar
Originally Posted by Marty Rinehart Jr View Post
We use and sell Brown & Miller Racing Solutions hoses and crimped fittings.
Nothing better!
Old 04-23-2024, 01:20 PM   #16
mham72
Liked 7 Times in 4 Posts
I have it on my bracket car. 6 years and no problems. The ends aren't the easiest to install, I found a little use of a heat gun on the hose before pushing in the ends helped a bit. Once in, they don't move.
mham72 is offline   Reply With Quote
Old 04-23-2024, 04:54 PM   #17
Jeff Kempton
Jeff Kempton's Avatar
Liked 66 Times in 30 Posts
What do you use for the transition fittings to go from aluminum line to braided or to system devices? Does the connection seal by means of a furrell, a flare, a swagelok, or something else?
Jeff Kempton is offline   Reply With Quote
