Old 01-22-2023, 12:52 PM   #11
Jim Hawkins
Liked 115 Times in 35 Posts
Default Re: Monocoque Wheels
How about rear wheels cracking? I have a set of 15x13 I would like to run but am concerned about stories of these wheels cracking. Was this a problem with fronts only? They are light.
Holeshot makes a similar wheel with the holes.
Jim Hawkins is offline   Reply With Quote
Old 01-22-2023, 01:35 PM   #12
John Dinkel
Liked 263 Times in 68 Posts
Never cracked a rear wheel only front wheels. I'm sure it's because wheelies and turning loads make it happen.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 01-23-2023, 07:41 AM   #13
SGSST109E
Liked 126 Times in 61 Posts
original Monocoque wheels were bolted. Picked up mine at Larry kopps house
SGSST109E is offline   Reply With Quote
Old 01-23-2023, 08:22 AM   #14
richie 2
Liked 204 Times in 93 Posts
larry brought me a new set to cauyga wwcs '82. beauty's they were.
Old 01-23-2023, 01:12 PM   #15
Race Clean
Liked 129 Times in 53 Posts
I had a rear rim crack right at the weld after about 10 years of use.
It was the 3 piece where the rims are welded together and center are bolted.
By then mr Bogart had taken over the business so I got in contact with him.
I got an explanation about the crack and that was that the ¨old Monoqoque management¨ at the time was using up a stock of some older inner rim halves to save money that where not made to go together with just that outer rim for welding by ending up so the V you need to put a good weld in place couldn't be had because one rim half went straight up another inch compared to the outer rim causing uneven stress on the rims at the weld.(yes it cracked on the rim that was straight)
Sent both wheels and Bogart fixed the wheels (both) with the right inner halves.
I still like them and will keep on using them,
Stop global whining
Race Clean is offline   Reply With Quote
