Old 11-26-2021, 10:37 AM   #11
mschafer
Liked 13 Times in 9 Posts
Thumbs up Re: Leakdown Testers
I have a OTC also ,works well and would recommend it.
mschafer is offline   Reply With Quote
Old 11-28-2021, 06:12 PM   #12
Dave Bergfeldt
Liked 8 Times in 6 Posts
Default Re: Leakdown Testers
Do Not .... I repeat Do Not get the Harbor Freight unit ... Difficult to use ... inaccurate numbers!!!!
Dave Bergfeldt
106 SST/SG
Dave Bergfeldt is offline   Reply With Quote
Old 11-29-2021, 09:13 AM   #13
sst5167
sst5167's Avatar
Liked 17 Times in 9 Posts
I bought mine off a Cornwell truck quite a few years ago. I use mine after every race on both car as part of my routine maintenance, and it's been perfect. I would buy another one if I needed too.
sst5167 is offline   Reply With Quote
Old 12-12-2021, 04:27 PM   #14
reknapp52
reknapp52's Avatar
Liked 7 Times in 5 Posts
Turns out my brother has a Matco tester that I will be using. Do I need to warm the motor before running the test? It's been parked in my garage for about 3 weeks without being started. Also, what numbers are acceptable? My motor is 447 C.I. with 14.3 compression.
reknapp52 is offline   Reply With Quote
Old 12-13-2021, 07:43 AM   #15
SGSST109E
Liked 126 Times in 61 Posts
You can leak a motor cold or hot. Just do the same thing each time. A warm motor should leak alittle better the cold. If doing cold just spin the motor over a few revolution to make sure you have some oil on the walls. Certainly under 10% mine usually leak 3 to 5% when fresh cold
SGSST109E is offline   Reply With Quote
Old 12-14-2021, 02:01 PM   #16
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Had an OTC for years with no issues
sst7250 is offline   Reply With Quote
Old 12-18-2021, 02:24 PM   #17
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Depends a lot on the ring type and end gap. Also piston to wall clearance will effect the readings. 10 or better is what you are looking for. You don’t want any blow by on the intake valve. That is a killer. Also equal across all cylinders is another good sign. Leak down is a tool not a tell all.
Mike Pearson 2485 SS
Old 01-31-2022, 02:49 PM   #18
garyc
Liked 51 Times in 30 Posts
whats normal leak down on a new motor? does it matter what ring package?
thanks mike
garyc is offline   Reply With Quote
Old 01-31-2022, 04:50 PM   #19
garyc
most times leak down was used to find a dead cylinder
Old 01-31-2022, 06:29 PM   #20
FED 387
Liked 333 Times in 180 Posts
definitely less than 10% and if you have gapless end rings less than 5%---if its a tight motor AND NEW never started you are going to see about 3-4 to maybe 5 - 6 %---watch for variations between the cylinder readings especially those cylinders that are next to each other-- not small ones like a few percent but big differences like 10-30%--FED 387
