Old 07-22-2021, 10:37 PM   #11
Dragsinger
Liked 99 Times in 60 Posts
Default Re: "Family Tradition" a build for Daughter & Grandchildren
We are beginning the frame modification. The new section will be 5 1/2" inboard of the original frame. Once both new sections are properly installed and aligned, the original frame will be cut away. Having the OE frame remaining in place gives a good fixture for accurate alignment.
Larry Woodfin 471W
Old 07-23-2021, 08:28 PM   #12
Dragsinger
We have good progress with the new frame section. When this is finished, the attaching points will be boxed and triangulated. Plus, the shock cross-member and roll bar rear struts will tie it all together
ID:	57873   Click image for larger version
ID:	57874   Click image for larger version
Larry Woodfin 471W
Old 07-23-2021, 09:05 PM   #13
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
'Singer... Are the rear tires like a 29.5 x 11.5 or 14 x 32? MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 07-23-2021, 09:20 PM   #14
Dragsinger
Maurice, 29.5 x 11. The wheels and tires pictured are for mockup, and I will likely run a radial in the 29.5 x 11 range. The bias tires pictured are new but several years old. I might run the bias for a few test outings.
Larry Woodfin 471W
Old 08-02-2021, 04:43 PM   #15
Dragsinger
A few updated photos.
ID:	58112   Click image for larger version
ID:	58113   Click image for larger version
Larry Woodfin 471W
Old 08-02-2021, 05:05 PM   #16
Dragsinger
When the frame mods are complete, all will be braced and triangulated as needed. Another cross-member will accommodate the shocks, and the Antiroll bar will be in front of the diff.
Larry Woodfin 471W
Old 08-03-2021, 06:01 PM   #17
Dragsinger
Old reliable, simple, easy, ladder bar.
Larry Woodfin 471W
Old 08-04-2021, 05:10 AM   #18
Dragsinger
Job change note: I originally planned on utilizing CalTracs, but after a time of pondering, I changed by mind [I do that ofter] and decided to make room for a wider tire and install the ladder bar set.
Larry Woodfin 471W
Old 08-04-2021, 04:16 PM   #19
Dragsinger
The ladder bars and shocks are as far outboard as the new frame will allow. The pinion is centered.
Larry Woodfin 471W
Old 08-11-2021, 02:13 PM   #20
Dragsinger
A fellow could buy a kit to do such a modification, but I like the challenge and the thought process of a custom design. I will have the overall idea in mind, but the steps between the beginning and the end are a process of one step at a time with some deviation along the path.
ID:	58231   Click image for larger version
ID:	58232   Click image for larger version
Larry Woodfin 471W
