Liked 229 Times in 75 Posts
At the divisional I had both fronts leak, bad enough to get out of the lanes and go back to my trailer and fill one up. I took them off put them in water and found the rim to be leaking between the halfs. These are a 3 piece rims american racing wheels. I had taken them apart and had them hydra dipped. I put them back together and used a clear silcone between the halfs and ran a bead of silcone where they 2 halfs meet and smoothed it out with my finger. Is there there something better to use than silcone? could I put something over the silcone to stop the leak? Or am I starting to remove the silcone and start from scatch?
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
Liked 51 Times in 30 Posts
"as seen on TV" arresol gutter seal
Liked 1,958 Times in 593 Posts
Typically once you use silicone sealant on something you are stuck with it. Its almost impossible to remove all of the residue from silicone sealer. There are some different grades of silicone sealant. You might look for an acid cure sealant. You wont find that at your local home depot or hardware store. You would have to look at a commercial sealant supplier. I know Dow Corning makes it. reseal the wheels and let it cure for about a week before you put pressure on it.
Mike Pearson 2485 SS |
Liked 886 Times in 238 Posts
I've had good luck with urethane windshield sealer .
You have to get all the old sealer off and use the primer ,but I've not had any that I've done leak.
Liked 706 Times in 283 Posts
So far I tightened the bolts on my 3 piece Weld as they were leaking. Checked and tires are still up. Will watch others opinions in case I need to take them apart.
The best sealant for 3 piece wheels is Dow Corning 832 sealant
Also as suggested: Urethane Windshield Sealer or Permatex Ultra Grey. Clean the halves very wheel, torque the bolts in a sequence and then apply the sealant to the joint. RTV Silicones that are acetoxy catalyzed, release Acetic Acid while curing and not good for Aluminum or Magnesium wheels. As Mike Pearson stated, you need to use a light acid based cleaner to remove the residue and clean thoroughly with Acetone or MEK.. |
Liked 3 Times in 2 Posts
Ultra gray gasket sealer. Clean well, apply, bolt together, clean up excess, let dry for 2 to 3 days. They will be extremely hard to take apart the next time.
Arnold Greene IHRA/NHRA 2420 A/S, B/S |
