02-24-2021, 09:50 PM | #11 |
Liked 799 Times in 178 Posts
Re: Decal adhesive remover
Lighter fluid works great. Get it at home depot under the name Naphtha.
Bob Don 128 SS |
02-25-2021, 07:40 PM | #12 |
Liked 966 Times in 268 Posts
Any idea what this Turtle Wax product is called?
02-25-2021, 09:10 PM | #13 |
Liked 300 Times in 160 Posts
Turtle Wax T-159 "label and sticker remover"--its an aerosol 10 ounce about $10-15 per can depending where you guy it--FED 387
02-25-2021, 09:19 PM | #14 |
Liked 4,800 Times in 1,824 Posts
H-F heat gun, blue shop towel, 87 octane...$2.50 a gallon ;-)
Real life never quite adds up.... Jay Farrar |
02-26-2021, 08:45 AM | #15 |
Liked 775 Times in 232 Posts
Ended up using a product called Goof Off Pro Strength. It softened the adhesive and then a scraper rolled the adhesive off. These little scrapers are pretty slick...different shaped corners helped conform to the curves the body has.
Thanks for the suggestions. -Al
"That'll never work....." |
02-26-2021, 12:01 PM | #16 |
Liked 85 Times in 43 Posts
Al, Where did you get the Goof Off Pro Strength?
PS. I got the tires and gave John the $. Thanks
Bob Tilton 568 FS/H |
02-26-2021, 04:32 PM | #17 |
Race gas works very well as does WD-40. After either just use a window cleaner to get rid of any residue.
Never had any issues with them damaging paint.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
02-26-2021, 05:55 PM | #18 |
Liked 286 Times in 159 Posts
You guys should know that most racing gas contains lead and that it is easily absorbed through pores in your skin. Lead is one of those heavy metals that the human body can not get rid of. Try unleaded fuel or stick to the WD-40.
02-26-2021, 06:52 PM | #19 |
Liked 38 Times in 14 Posts
Brake Kleens works great with out harming the paint.
02-27-2021, 11:28 AM | #20 |
Liked 56 Times in 27 Posts
Try using a Spray Lubricant ( Wal-Mart ) $1.99 & soft towel and rub lightly !!!
It will be gone in a few mins. and the paint will have nice protective shine .. It also removes rubber & dirt / grease .. Good luck
Dave Ribeiro 1033 STK |
