Old 09-16-2020, 07:58 PM   #11
jmantle
Liked 172 Times in 81 Posts
Default Re: new swap firing order camshaft
If your Stock Eliminator engine has a dual plane, save your money. The pulses on the intake manifold will be disrupted by the changed firing order.
Trying to figure this out in my head. By what I remember, an LS is 18726543.
On a dual plane, this would be alternating between planes so why would there be an issue?
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 09-17-2020, 09:50 AM   #12
Bobby Lundholm
Liked 127 Times in 49 Posts
I spoke with Chris at Bullet and he said no benefit on power for a Stocker setup.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 09-17-2020, 01:55 PM   #13
SSDiv6
When intake runners are designed, the location of the planes and fuel/air distribution of the intake are based on the firing order pulses, especially for torque and low end power. The runner length, size and height are not always the same on OEM dual plane intakes. A changed firing order also may effect the location of the primary tubes on the exhaust collector.
Old 09-19-2020, 10:14 AM   #14
Adger Smith
Liked 880 Times in 311 Posts
Bobby, if you spoke to Chris then you probably spoke to the real "Father" of the swap. First one I had was back in the 70's from Lunati (M/P tunnel Ram application) and I was later told he was the brain child. I never have ask if that was really the case. Guess by now it doesn't matter who gets the "Father" tag because all the companies have turned it over to the marketing Guys.
BTW if you guys take time to trace the firing impulses vs the runner locations on dual plane intakes you should be able to see how the change just causes more induction problems on most dual planes.
Adger Smith (Former SS)
