Old 07-22-2020, 07:55 AM   #11
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Advice of Dana 60 Gears
IMHO the gear sets need more backlash, AKA Space, for the gear lube to build a film for the gears to mesh on. I'm thinking the .008+ Up^.. If the pattern doesn't look right you can usually adjust the pinion depth to get the pattern right at that backlash. Some where I have a 1962 Motor Manual that explains the back lash pinion moves vs pattern location.
Adger Smith (Former SS)
Old 07-23-2020, 04:18 AM   #12
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
.003 - .004 seems kinda tight to me.
Dave Noll, EF/S ,?/SA 6526
Old 07-23-2020, 07:35 AM   #13
SGSST109E
Liked 126 Times in 61 Posts
Needs to be .010 to .012
SGSST109E is online now   Reply With Quote
Old 07-28-2020, 04:03 PM   #14
65signet
Liked 49 Times in 22 Posts
Originally Posted by GTX JOHN View Post
Are the Richmond gears the best choice?
I will probably get Street gears unless I really
need Pro Gears?
Thanks to everyone for the Help!!
I switch to US gear, and like them, the old Richmond gears the double diamond are good, but i think they have had multiple buy outs over the years, and quality is not the same.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 07-31-2020, 09:28 AM   #15
ss125h
Liked 80 Times in 28 Posts
John, I run same car, but a lot less torque (340) with 8.75 ,point is we always have the gears heat treated. Have had very few problems, even running close to 3700 lbs. We do run 6-12 thou. bk-lash, with auto trans. good luck. Glen H 1257
ss125h is offline   Reply With Quote
Old 07-31-2020, 10:39 AM   #16
Frank Castros
Liked 2,798 Times in 983 Posts
There was some positive reviews about Motive Gears that are manufactured in Italy.
Old 08-01-2020, 01:53 AM   #17
GTX JOHN
Thanks.............Appreciate the help!
John Irving
741 Stock
741 Super Stock
Old 08-01-2020, 02:38 AM   #18
mikeloge
Liked 130 Times in 35 Posts
john don't complain about 200-220 check them real good at 100 replace at 160-175 never in 50 years have we got 200 out of dana gears we have 5.13 in our satellite with 2.94 low gear set so could make a difference and chads car also pretty heavy in C/SA this is my 2 cents
mikeloge is offline   Reply With Quote
Old 08-24-2020, 10:26 PM   #19
thekidd
Liked 4 Times in 2 Posts
John get a pro gear set it up right .010 to .012 backlash you will get thousands of runs out of it I always say set it and forget it
thekidd is offline   Reply With Quote
Old 08-25-2020, 06:54 AM   #20
Liked 11,032 Times in 2,267 Posts
In the A B C six pack car we got over 15 years of service from a pro gear Dana. 3700# in C to 3200# in A
