Liked 547 Times in 93 Posts
Not Legal in Stock ,,, correct ?
Liked 193 Times in 60 Posts
My engine guy told me that Jesel experimented with roller cam bearings and the negative harmonics were real bad. That was quite a few years ago, maybe someone found a way to correct?
#3 | |
Liked 18 Times in 10 Posts
It takes more power to move all those needle bearings VS the cam sliding on a film of oil. I blue print bore a lot of blocks for 55MM cam journals for other shops and builders babbit seems like the way to go. Also machine some of the OEM 350 blocks to 2.120 and use the GMP-1 cam bearings for BBC journals. |
#4 | |
Liked 371 Times in 129 Posts
Carl Some years back I had a contract to build Winston West 9.1 comp 390 carbed 358 engines. We were quite sucessful and won several races, every engine we built had roller cam bearings, but also were dry sump. I never saw any weird stuff going on in those engines, they made right at 600 HP. Not going to say there was no harmonics, but we never had problems. We also built some with 55 MM babbit, I never saw any difference on the dyno, I did like getting rid of the oil leaks. Last edited by HP HUNTER; 05-21-2020 at 10:30 PM. |
Liked 70 Times in 22 Posts
Anyone have any experience with roller cam bearings on the street. I have 2 Gen3 hemi aluminum blocks that have been cut for 60mm roller bearings. These are in a cam tunnel so no oil from the top and I don't know if you could put a hole in the bearing cage for oil without hurting the bearing. These are destroked and bored to 305" and Bryant cranks and blocks are cut for LS chevy bearings to get a full thrust bearing for road racing. I was thinking of 1 for a street rod but not sure the bearings would oil enough at low RPM on the street. Any thoughts?
Stewart Way 2424 SS |
#6 | |
Liked 965 Times in 306 Posts
#7 | |
Liked 1,538 Times in 575 Posts
Liked 772 Times in 192 Posts
Isky "Imperial" camshafts.
#9 | |
Liked 987 Times in 271 Posts
Duane Hoven 1342 SS/GT |
#10 | |
The 55MM bearing you used probably had 3 oil holes = huge oil, A few years ago I had 55MM babbit bearings designed with one oil hole and a groove. A lot of my customers have said going from Roller to babbit once the adjust the valves nothing changes in lash going to babbit which is good indicator there is less harmonics having the cam floating film of oil VS iron to iron. |
