#11 |
Liked 5,151 Times in 1,966 Posts
That's right . At least I don't have to take them to Camping World ..yet!
#12 |
Liked 162 Times in 45 Posts
WELL- I’ve never been accused of being snobby before, that I know of. And I have absolutely no idea who Dano is if he isn’t cuffing anybody. I am just trying to to help somebody I don’t know make the correct transmission choice. I think I might be qualified to make that suggestion. You I don’t know about. So you can kiss my snobby but.
#13 |
Liked 2,350 Times in 466 Posts
Ding Ding Ding we have a winner. Have it with a turbo spline. BP
#14 |
Liked 536 Times in 110 Posts
Guys need to keep in mind that not every single stock class racer may be willing to spend $6,000+ on name built TH-200 or Pro Trans that is built to withstand a big block. I've priced both for my own car. I run a lightweight TH-350 in my car and find it hard to justify the added cost vs. the little gain in E.T. Personally, I see lots of other areas where that kind of money could be better spent. One could install top-of-the-line ignition and fuel systems, plus a data logger for that kind of money and probably have a few bucks left over. Just my .02.
Jim Kaekel 3836 STK |
#15 | |
Liked 49 Times in 15 Posts
1) In your first post, you mention 5:14 rear gear. That's a bunch of rear gear for a car that should hit 125 MPH. You are going to need a really good BBC. 2) You stated that you already have the converter. The converter should be the last thing you buy, built to the finished engine/transmission/rear gear/tire combination. 3) There is a lot more to converters than stall. "K" factor, lock up potential, plus fin and stator design are all factors in the converters performance. 4) If you already have a real Kilgore, you already have an "expensive" transmission. 5) If you are looking at Coan, you are looking at an "expensive" transmission. 6) If your transmission was just open and your transmission guy could not tell what ratio was in it...well to be blunt, you need a better transmission guy. 7) If you have a real Kilgore, he has multiple ratios available. Disclaimer: These are my opinions and not be confused with facts or snobbishness.
Dean Feiock -- Stock 5002 |
#16 | |
Liked 52 Times in 32 Posts
BTW, the Snob comment was directed to only one post. To others that were actually trying to help, thank you. |
#17 |
Liked 319 Times in 68 Posts
Not for nothing with the combo you're running you better adjust your budget or change combos. The price of a TH-200 is going to be one of your lesser expenses.
Lee Valentine 1661 STK |
#18 | |
1) car runs 122 mph with old converter 2) Converter matched to all you've mentioned 3) Above my pay grade right now 4) This I know 5) Coan is on the way (when referring to "expensive" I consider $ 6500.00 and up to be expensive) 6) You are correct 7) Again, you are correct Disclaimer: When advised to get rid of my Motorhome Transmission, yes I considered that "snobby". Most of the replies I got were considerate/helpful as yours was. |
#19 | |
It happens to be true, and just an extension of someone else's point . Peace brother, and happy holidays.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 12-18-2019 at 06:23 PM. |
#20 |
Liked 32 Times in 19 Posts
Remember sec0nd gear is important in heavy car too. 3600 lb bbc wi 815 hp 2.75 low helped.
