09-20-2019, 12:54 PM | #11 |
Liked 157 Times in 44 Posts
Custom Mark Williams 12-bolt
For the Nova "sleeper" build, I'm using a pretty cool custom built 12-bolt from Mark Williams. It's a super neat piece with 35 spline axles, a 35-spline Detroit Locker, a custom DTS case, moly axle tubes, unit bearings and more. It also looks pretty close to stock (perfect for my sleepy little Nova application). This is part one. I'll follow up with part two (axles) next week. Hope you dig it and thanks for watching! Please subscribe!
09-26-2019, 02:28 PM | #12 |
Liked 445 Times in 83 Posts
Re: My 1970 Slow Poke Nova Build
Do yourself a favor and save up for gun drilled axles, they are worth it. Also, if you're going to put an exhaust system under the car, get electric cut outs. I have both on my car and it's fun to race with.
Casey Miles 248H E/S |
09-26-2019, 02:31 PM | #13 |
I've used gun drilled axles before (first set was in 1996), but this car will see street use so its conventional axles for this go-around.
09-26-2019, 02:50 PM | #14 |
If you're going to put on an exhaust system, on my 1969 Camaro Z/28 I have a 2.5 inch flowmasters with electric cut outs. The car will run only .15 to .18 slower through the mufflers rather than open headers and they are pretty quiet. Just a recommendation from experience. What I do is run the car with open cutouts, qualify with that number, make a pass with mufflers and dial the car through the mufflers.
Casey Miles E/S |
09-27-2019, 11:36 AM | #15 | |
09-28-2019, 10:23 PM | #16 |
Here's an update on my Nova Build. This is actually part 2 of the rear end video. This one discusses axles. You might find the tech interesting.
10-12-2019, 09:15 PM | #17 |
Garage Hacks
While working in the shop (and in this case, on my sleepy little Nova project) I regularly stumble into "problems". So I have to come up with "solutions"....L-O-L. And some of those solutions turn out to be good old-fashioned garage hacks. I compiled six of them in video format that actually worked pretty well. They're certainly not fancy and they're sure not expensive. Check 'em out (click to view):
10-21-2019, 08:56 PM | #18 |
Update on my Nova Build
Here's an update on my Nova build. If you dig it, please subscribe to my YouTube channel. I need all of the help I can get...L-O-L. And thanks for watching!
11-10-2019, 07:17 PM | #19 |
Garage Hacks #2 is "Live" - Up and Running. 😄 There should be something here you can use -- check it out! I had fun making it. 😜. Next time around, I'll post an update on the Slo Poke. It's rolling right along!
11-28-2019, 10:56 PM | #20 |
Here's Part Six of my Nova Build. And hey, please subscribe! That's what keeps me motivated!
