Old 03-13-2019, 04:54 PM   #11
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
Default Re: bellhoushing
Originally Posted by Rory McNeil View Post
Stephen, do you have a QuickTime in the Fairlane? If so, with what clutch? I had heard that on a FE Ford the QuickTimes were not deep enough to work with a Long style pressure plate with a 10 or 10 1/2" disc, unless you stacked up block plates to get enough room. What is your experiance with the FE?
10in soft loc clutch. Did not have any issues . We lost a lot of weight over those lakewoods.
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 03-13-2019, 05:31 PM   #12
J&S Racing
Liked 327 Times in 87 Posts
Recently did my McLeod aluminum bellhousing. After fighting with the parallel I decided to remove the powder coating. Ended up being the ICT billet spacer I was using, it was off .010 from the dowel holes to the top. My concentric on the other hand was way off. I ended up using the Robbmc dowels.
Old 03-14-2019, 04:11 PM   #13
Chevy55
Banned
Liked 179 Times in 89 Posts
As a old IH truck mechanic we were required to make three checks when there was a clutch disengagement problem.
1. flywheel parallel to the block (dial indicator on block, turn crank to check flywheel face)
2. face of Bellhousing parallel to the flywheel (dial indicator on flywheel, check bellhousing face when turning crank)
3. center hole in the bell matching the centerline of the crank.
Chevy55 is offline   Reply With Quote
