Old 02-15-2019, 04:10 PM   #1
JCChildress
JCChildress's Avatar
Liked 13 Times in 6 Posts
Default Fuel "cool can"
I'm sure this has probably been beat to death previously. Has anyone ever done a back to back comparison on using a cool can versus not using one ? Does anyone even make one these days, as I know Moroso has stopped production. Thanks in advance
JCChildress is offline   Reply With Quote
Old 02-15-2019, 08:16 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Fuel "cool can"
Canton still makes one but its a little pricey. Over $200 but it does look like a nice.
Old 02-16-2019, 01:03 AM   #3
House of Darts
Liked 20 Times in 15 Posts
Its cooler/denser air that makes the HP.
House of Darts is offline   Reply With Quote
Old 02-16-2019, 01:13 AM   #4
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
Wink Re: Fuel "cool can"
back when dad was driving the car, he was trying to set the ihra record and had I said hey lets try some ice in the cool cans.he said sure go ahead and pour it in... He went on out on the 2nd pass and beat his previous pass by a .10
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 02-16-2019, 10:32 AM   #5
Ralph A Powell
Liked 227 Times in 138 Posts
Depends how big a electric pump is bypassing fuel which heats up the fuel.
Old 02-16-2019, 07:38 PM   #6
Ed Wright
Ed Wright's Avatar
When I had my '56, I was an aircraft technician. I had our sheet metal shop make me a box, mounted next to the front of the radiator. Was about 6" x 12", (not round) with a -6 an fitting (with an -6 an cap)TIG welded on, drained water right through the factory radiator drain hole. Used aluminum tubing, transfers heat better, top flap/lid was on hinges, with aircraft latches to hold it shut. Testing with it bypassed, or full of ice, fuel lines sweating at the carbs, was a solid 8 hun quicker cold. At Fuel Check, near the scales, those old Carter WCFB float bowls would feel cold, and sweating.
People can repeat "only air temp matters", it's another thing Jere Stahl told me to do, and he was correct. I am not the only person having the same experience with that.
I know a fast Pro Stock car that cools fuel before pouring it in the car, and icing the fuel cell.
That was my experience. Right or wrong.
Ed Wright 4156 SS/JA
Last edited by Ed Wright; 02-16-2019 at 07:39 PM. Reason: Still can not type. Sorry.
Old 02-17-2019, 10:11 AM   #7
Ralph A Powell
Ed you absolutely correct on this!
Old 02-17-2019, 11:10 AM   #8
Chevy55
Banned
Liked 179 Times in 89 Posts
I guess this rule pretty much made cool cans obsolete.
General Regulations Section 21, page 5
Fuel/Air:
Any method of artificially cooling or heating fuel prohibited (i.e., cool cans,
Freon, wet rags, etc.), except as noted in Class Requirements. Cool cans,
wet towels, etc. are permitted in Super Stock, Stock, Super Comp, Super
Gas, Super Street, and E.T. classes. Wet towels, rags, ice, etc. must be
removed before vehicle leaves staging area. Coolers, chillers, etc., where
permitted by class requirements, are prohibited outside of the
competitor’s pit. Ambient-temperature air only; cooling or otherwise
changing the conditions of the intake air is prohibited. Spraying of intake
with any artificial spray or coolant prohibited.
Chevy55 is offline   Reply With Quote
