#11 |
Liked 18 Times in 10 Posts
#12 |
#13 |
Liked 692 Times in 205 Posts
Ritchie check your pm now
Carl they have oil fluctuations I sell Oil restrictors specifically for this block made out of 6061 t6 comes with rubber o-ring. Have sold hundreds of these and everyone comes back and tells me problem solved, pressure is solid and does not vary once they are installed. |
#14 | |
Liked 977 Times in 312 Posts
#15 |
Glenn works on both solid and hydraulic lifters
#16 | |
To date no problems here I guess if you know what you doing there is no problems. I checked with Dart and they have not heard of any or seen any problems either. |
#17 |
Have been selling them for years along with Allstar Performance. Mine are exactly the same ones they sell (made by same mfg.)
Obvious there is a need for these. https://allstarperformance.com/oil-r...hole-all90072/ Last edited by nickh; 04-14-2019 at 12:12 PM. |
#18 | |
Check with any roller lifter company on using restrictors with their lifters see what they say. I have sold well over 250 SHP blocks and to date I have had zero problems with oil pressure. Like I have said if you know what your doing you should be fine. Dart has built and sold how many SHP blocks and engines and their not seeing any problems I just got two SHP blocks and Dart has sold over 32000 SHP blocks and nothing in the instructions mentions any oil problems and you have to run restrictors. The biggest oil bleed off with any Dart block is using cam bearings with 3 oil holes something I don't do. Many guys pay no attention to lifter bore clearance either. Something I always address. Here is a video that shows the difference in lifter sizing between companies Last edited by carl hinkson; 04-15-2019 at 08:12 AM. |
#19 |
