Old 10-25-2018, 06:04 PM   #11
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Default Re: Man. trans for Stock
When I was building my 68 Camaro a few years back,I had to buy the entire set up for a stick.I talked with Rob Youngblood and John Calvert,both said without hesitation to run a 101A.Good enough for me.
Matt Welker-what sensor and V-net cable do you run? I had trouble getting a good clutch graph on my racepak sportsman with various combinations of cables and sensors.Went to the picking up the signal off my input,works fine.
Dana Fitzpatrick is offline   Reply With Quote
Old 10-25-2018, 06:20 PM   #12
Matt Welker
Liked 77 Times in 15 Posts
Clutch RPM Module with Sensor Part No. RAC-220-VP-CL-1
Never had an issue with either car, and we have sportsman systems in both stockers. We have always picked up using a magnet in the input shaft using that part, never tried anything else. Always works, if it stops working, it has probably threaded out and lost the required gap to the magnet, and improper gap will also give you really weird graphs.
With Input and DS speed and a few simple math channels, you should have everything you need.
Matt Welker
Stock 1741, SS/AH 114
www.facebook.com/welkerracing
Matt Welker is offline   Reply With Quote
Old 10-25-2018, 06:32 PM   #13
Wayne Totaro
Liked 39 Times in 13 Posts
With out a doubt it is G-Force! Bubba and Paul are Great to deal with. Their stuff is tough as nails.
J. Wayne Totaro 1117 STK
Wayne Totaro is offline   Reply With Quote
Old 10-26-2018, 08:33 AM   #14
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Originally Posted by Sean Marconette View Post
Tony,
G-Force, Call and ask if they have a trade in. It will be at a reduced cost, plus they will go through it and update it. You can get whatever ratios as well.
Sean
I have heard from other racers the same thing.
That buying a used/refurbished one is a better choice
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 10-26-2018, 10:35 AM   #15
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
G-Force! You will NOT regret it!
Joe Martens AA/Stock 3969
Joe Martens is online now   Reply With Quote
Old 10-26-2018, 10:54 AM   #16
Dana Fitzpatrick
Thank you Matt. Sorry, I didn't read your first post correctly.That's what I ended up with,magnet in the input.I started off with the case drilled,and picking up the tooth count on the input gear.
Old 11-01-2018, 09:23 PM   #17
Don Anderson
Liked 24 Times in 8 Posts
Talking Re: Man. trans for Stock
Liberty Gear 5-speed with the Long shifter.
They will get you the trans ratios you need for your combo.
Don Anderson is offline   Reply With Quote
Old 11-02-2018, 07:21 AM   #18
Ralph A Powell
Liked 225 Times in 136 Posts
Much better service from G-Force
QUOTE=Don Anderson;576108]Liberty Gear 5-speed with the Long shifter.
They will get you the trans ratios you need for your combo.[/QUOTE]
Old 11-02-2018, 08:42 AM   #19
Nmbr1GMfan
Just looked at the G-gorce ratio chart, impressive.
Todd Greene
Old 11-04-2018, 09:01 PM   #20
Don Anderson
Always have had great service & price from Liberty Gear.
[/QUOTE]
