Old 09-18-2018, 08:37 PM   #11
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: Electrolysis in aluminum radiator - Help
Ill have to pickup some strips to check ph.
Yellow optima is out of truck. Using 10ga wire with eyelet on one end and heavy test clamp on other to ground each head to steering box bolt ends....still have .5v
My buddy brought over his fluke last nite and we tested turning on/off fan, fuel pump and water pump with no change.
No voltage leak at battery to the bed where it is mounted...
Please keep advice coming.
Thank you
Old 09-18-2018, 09:03 PM   #12
Mark Ugrich
Liked 71 Times in 38 Posts
Are you thinking it is the electrolysis that is causing the hoses to bulge? Not saying it isn’t possible , but I’ve never heard of that occuring. Is there a voltage reading with the anode removed?
Old 09-18-2018, 11:26 PM   #13
Barry Polley
Guest
Posts: n/a
http://www.ve-labs.net/products/rad-cap
David Reher talked about grounding alum heads to block. We saw issues early on in police car builds. Electrolysis killed heater cores and radiators yearly. We tried everything you spoke of. Ended up replacing rad caps every three months.
Old 09-19-2018, 01:26 PM   #14
cad
cad's Avatar
Originally Posted by dragracedr View Post
out of curiosity, do you run a battery tender? I had a similar problem, ate 2 radiators and ruined 2 batteries. Tender was overcharging and backfeeding through alternator/chassis from battery side of cut-off switch.
I have but usually only when racing is longer than 2 weeks apart.
Old 09-19-2018, 01:28 PM   #15
cad
cad's Avatar
I believe the hoses were hard from gasing. Same voltage with and without the anode.
I grounded 1 head to the steering box bolt, and the other to the upper control arm stud, and no noticeable change in voltage...still .5'ish
Old 09-19-2018, 01:41 PM   #16
cad
cad's Avatar
Here is 1 article penned by David Reher...
http://garage.grumpysperformance.com...n-cooling.149/
I will have to have my old man come back over and re-check the grounds.
He put heavy star washers under all of them, but I wonder if my paint job on the frame isnt scuffed enough under those grounds.
Old 09-19-2018, 02:16 PM   #17
Barry Polley
Guest
Posts: n/a
Forgot to say; Test the alternator for a leaking diode if you have not done so. Seen lots of those and yes it reduced cooland voltage.
Old 09-19-2018, 03:09 PM   #18
Bobby DiDomenico
Liked 101 Times in 52 Posts
Originally Posted by 6130 View Post
If he's still got voltage with everything disconnected / shut off, then it's not the car's electrical system.
I used to race a rotary Mazda Pro ET door car, and if you didn't keep an eye on the pH of the coolant, it would literally eat a hole through the engine. The engines are even built like a battery- cast iron front plate, aluminum rotor housing, cast iron intermediate plate, aluminum rotor housing, and cast iron rear plate, all filled with the same coolant.
He's got a cast iron engine connected to an aluminum radiator by two rubber hoses, filled with the same coolant.
My money's on the pH of the coolant.
That's what I'm thinking, it is chemically making voltage. Just not sure if "battery disconnected" means all batteries removed rather than just a positive or negative cable disconnected from the big one.
Old 09-19-2018, 03:32 PM   #19
6130
Liked 117 Times in 50 Posts
Yup.
Have you ever media-blasted an aluminum component after an electrolysis problem- it's horrifying. It can look like the part in your hand is all aluminum and intact before you start, but when you start blasting, the cancer is cleaned away, and you're left holding something that looks more like a piece of Swiss cheese.
Old 09-19-2018, 10:01 PM   #20
Kenney Kelley
Liked 72 Times in 36 Posts
Mark you said you've raced the S-10 all season and within the last two weeks this problem has come up. In the last 3-4 weeks have you changed anything on the car?
Kenney Kelley
Kenney Kelley is offline   Reply With Quote
