Old 08-12-2018, 05:07 PM   #11
Bill Bagley
Bill Bagley's Avatar
Liked 31 Times in 10 Posts
Default Re: Stocker Low Compression Approved Fuel.
Originally Posted by Adger Smith View Post
Bill,
Is there a jetting or timing difference in the two fuels?
It was at the tail end of the dyno session and we didn't compare any farther than switching from one fuel to the other, so I don't have an answer to that one.
Bill Bagley
4561 STK
Endeavor to Persevere!
Bill Bagley is offline   Reply With Quote
Old 08-12-2018, 05:55 PM   #12
Ed Wright
Ed Wright's Avatar
Originally Posted by ron mattson View Post
C11 works well, better than the older
Sunoco supreme, have not tried the newer
unleaded fuels, c25 was a tick quicker but
Expensive as stated earlier would only use for class
or heads up.
Ron, which engine do you run?
Ed Wright 4156 SS/JA
Old 08-12-2018, 07:49 PM   #13
ron mattson
Liked 67 Times in 30 Posts
I ran the 255/350, 295/350, 278/350and now the 1970
lt1 360-325/350
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 08-15-2018, 01:39 PM   #14
e vassar
Liked 271 Times in 107 Posts
Renegade R11 is a good option also.
Old 08-15-2018, 05:32 PM   #15
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by GTX5877 View Post
Sunoco tech recommends Sunoco 'Surge' as their best low compression fuel at 105 octane over 260 GTX fuel. It is now on the the approved fuel list. Supposed to have some better qualities than 260GTX.
Technical Details 260 GTX
Color: Green
Octane (R+M)/2: 98
Research Octane: 103
Motor Octane: 93
Specific Gravity: 0.762
Weight (lbs/gallon): 6.3
Reid Vapor Pressure (PSI): 4.7
10% Evaporation (°F): 182
50% Evaporation (°F): 220
90% Evaporation (°F): 227
Stoichiometric Air/Fuel Ratio: 14.6
Oxygen (weight%): 0
Ethanol (volume%): 0
H/C Ratio: 1.76
Lower Heating Value (Btu/Gallon): 115800
Lower Heating Value (Btu/Pound): 18240
Dielectric Constant: 1.6
Leaded: No
Old 08-15-2018, 05:40 PM   #16
Dan Fahey
Dan Fahey's Avatar
Technical Details Sonoco Surge
Color: Light Yellow
Octane (R+M)/2: 105
Research Octane: 109
Motor Octane: 101
Specific Gravity: 0.714
Weight (lbs/gallon): 5.9
Reid Vapor Pressure (PSI): 8.0
Initial Boiling Point (°F): 90
10% Evaporation (°F): 125
50% Evaporation (°F): 210
90% Evaporation (°F): 225
Final Boiling Point (°F): 250
Stoichiometric Air/Fuel Ratio: 14.9
Oxygen (weight%): 0
H/C Ratio: 2.09
Lower Heating Value (Btu/Gallon): 111,975
Lower Heating Value (Btu/Pound): 18,650
Dielectric Constant: -0.2
Leaded: Yes
Old 08-16-2018, 12:26 PM   #17
SDT1DYI
Liked 455 Times in 147 Posts
Some good info to work with. Ran the new 350 2 barrel combo on pump gas last weekend. 1/8 mile hits only. Divisionals this weekend . Will have C11 in It. Interested in comparing 1/8 performance of 3.50$ gas to 15.00$ race gas. Probably faster on pump gas.
STK. 6380.
SDT1DYI is offline   Reply With Quote
Old 08-16-2018, 04:08 PM   #18
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
Call Jason @ Insinger fuels, he will give you the lowdown on the Surge and any other Sunoco fuels, I have been doing some testing with the Surge for them and he has my info and others on the results.
Jason 5706376081
Duane
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 08-16-2018, 04:29 PM   #19
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
STK. 6380.
Be careful , Flush your fuel system out with race gas , or you could possibly get bounced at fuel check .
Old 08-19-2018, 05:24 PM   #20
Dan Fahey
Dan Fahey's Avatar
An you mix race gas...so long as it done now have ethanol.
Not all tracks carry the same fuel
D
