06-26-2018, 01:31 PM | #11 | |
Liked 353 Times in 83 Posts
Re: Valve Spring Pressure - BBC stocker
Not disagreeing with what you're saying, but if the opening ramp of the intake lobe is too close to "instantly vertical" (like what roller cam guys are using these days) the lifter can actually try to dig into the lobe and create milliseconds of valve train slack (shudder), which can cause things like valve spring surge. Even the roller cam guys admit that there is only so far you can go with "snapping" the valve open and closed. |
06-26-2018, 03:06 PM | #12 |
Liked 16 Times in 11 Posts
Do you run with Hydrolic lifter????
How many lash you have between rochers to valves 0 or 1/4 lap |
06-26-2018, 05:44 PM | #13 |
Liked 142 Times in 64 Posts
Spoke to COMP today, they are claiming that the lobe is so aggressive I need to get a different spring that is going to allow me the same open pressure, but within .050” of coil bind. He claimed that the spring is most likely doing the hokey pokey since it’s about .400” from coil bind, and not designed to work there. I thought pressure was pressure, but is this something that could actually be going on and therefore causing such an issue?
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
06-26-2018, 05:59 PM | #14 |
Liked 21 Times in 7 Posts
06-26-2018, 06:32 PM | #15 | |
Liked 278 Times in 153 Posts
06-26-2018, 07:10 PM | #16 |
Liked 1,126 Times in 297 Posts
What valves and pushrods are you using?
Alan Roehrich 212A G/S |
06-26-2018, 07:12 PM | #17 |
Ferrea Competition valves (not the hollow ones as I was told they are illegal) and trend 3/8x.120 wall pushrods
06-26-2018, 08:20 PM | #18 | |
Liked 70 Times in 39 Posts
How far open is the valve at the point of minimal valve clearance? Is it really going to "surge" at that point in the cycle? Could it be a bounce induced from the closing cycle? |
06-26-2018, 08:23 PM | #19 |
06-26-2018, 08:33 PM | #20 | |
