06-23-2018, 12:02 AM | #11 |
Liked 49 Times in 34 Posts
Re: K-frames on Mopar
Sounds like someone got caught. Could drill the holes bigger and use an offset bushing, or would the powers that be say thats a no-no?
06-23-2018, 09:25 AM | #12 |
Liked 230 Times in 122 Posts
They'd probably say no. It's hard to tell what's okay anymore. But they'd probably never know unless someone posted it on an open world wide web forum, that they've been known to read.
06-23-2018, 10:23 AM | #13 |
06-23-2018, 02:28 PM | #14 |
Liked 767 Times in 212 Posts
If you inclined to spend the time doing so, properly welding any body and chassis components, that were half ***** spot welded together with the QC of the 60s and 70s, will make a big improvement in any uni-body car. For the most part, they are pretty flimsy.
06-23-2018, 10:29 PM | #15 |
Liked 9,606 Times in 1,994 Posts
And if you do move the steering get ready to spend a little time on adjusting bump steer, with long and short tie-rods. Its never something for nothing.
06-26-2018, 10:27 AM | #16 |
Liked 70 Times in 39 Posts
06-26-2018, 12:03 PM | #17 |
Bump steer is always very time consuming, but on box relocation I have zero experience.
06-26-2018, 08:42 PM | #18 | |
I don't think I have seen a Hemi Dart/Barracuda that hasn't had the box moved some. I always thought Hurst slotted the boxes. |
06-26-2018, 11:52 PM | #19 |
The box is a stupid amount of distance from the frame.? Even the steering shaft is angled toward the engine and the whole drivetrain is offset over an inch or more to the right. At least I got the spindle to stay zero thru the up and down travel. Bump steer next. Got a hot torch and BFH.
06-27-2018, 07:58 AM | #20 | |
No matter what, once the first side is where you want it, you don't get to move the steering angle at all. And...that should be the position the steering is located as the car goes down the track. |
