Old 05-08-2018, 02:13 PM   #11
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Transmission Converter Options
I still think that this might work , with a 3.06 low gear and only running to 3rd . Big drop on the 1-2 shift which would need a looser converter to recover from , but the loose converter hurts upstairs with a heavy car , so lock up in high gear and get your mph back . Its worth a try , just need a converter company willing to help .
Old 05-08-2018, 02:19 PM   #12
Lee Valentine
Liked 319 Times in 68 Posts
Just on the drag factor a 200 should be a day and a half faster than a 4LE60 or us idiots have been doing it all wrong.
Lee Valentine 1661 STK
Old 05-08-2018, 02:25 PM   #13
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Russ, I have never thought that a deal like that absolutely would not work in Stock.
However, what Dan has on hand may work in Pure Stock, but it's all wrong, wrong, wrong for stock eliminator. You know that.
We're not trying to re-invent the wheel here. Just run a couple of tenths under the K/SA index. That is, I think that's the plan.
Going to have to agree with Brian here. Just set that o/d., lock up deal under the bench for now.
Mark;
YANK designed a strong converter and its costs a bit more.
Their Locking Converter uses a wider Clutch band.
Our Impala Club has Twin Turbo Cars that use the Locking Converter.
They have a lot more power than my car.
The Yank LC is a little heavier than other LC.
Yet works out well launching my 4100+ Lb car.
I understand how a lighter converter can work in a much lighter Car.
Towing you can Manually Lock the Converter for better mileage on flatter grades.
Vigilante and Edge are good too for racing but do not have the wider Clutch feature as the Yank.
Have 4.56 gears now not using the lock feature.
Same RPM range can use 5.38's or 5.13's with a 30 inch tall tire Locked.
Cruises great with the OD and converter locked.
As for getting under the K/SA 12.65 index.
Car is going to make a good bit more power and building reliability first.
Planning installing full up properly beefed 10 bolt Rear.
Still needs a Roll Bar and smaller gas tank.
Doing things in stages and still having fun a Pure Stocker.
One of the things learned from our Impala Club.
Build up the weak points before adding power.
Dan
Old 05-08-2018, 02:36 PM   #14
ss3011
ss3011's Avatar
I have seen hybrid converters with a 8" core , but a larger 298 mm clutch and front cover . That style converter has way too much inertia to work well in Stock . What might work pretty well is a 245 mm converter which is a lot lighter and only slightly bigger than a 8" Opel converter.
Personally I think you will need more rearend gear , but you can creep up on that , once you get going .
Good Luck
Old 05-08-2018, 02:47 PM   #15
Dan Fahey
Dan Fahey's Avatar
Good Luck
The 4L60E and R700 have a 3.08 First gear.
Great for launching.
BTW what RPM do you cross the traps at?
D
Old 05-08-2018, 04:48 PM   #16
ss3011
ss3011's Avatar
Totally agree with you . I had probably the first stocker to run a 200thm in my 83 307 Cutlass . Definitely faster than a 350 or a 400 .
I think Dan wants to work with a 4L60e , and that's cool too ! There are a lot of large diameter steel drums inside that beast , and I am not sure if any aftermarket company making aluminum replacements .
Old 05-08-2018, 05:06 PM   #17
Dan Fahey
Dan Fahey's Avatar
4L60E is what I have and know and it is built up.
For now going with what I have.
A built 200thm costs a good bit.
The R700 and 4L60E are stronger, right now prefer reliability.
They have similar internals.
Should already have some light weight race components.
This is a good conversation.
D
Old 05-08-2018, 09:21 PM   #18
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Feeling pretty good about my current Coan Lite TH350 w/low gearset vs the metric 200 so far.
Rich Taylor
I/SA - 321
Old 05-08-2018, 09:49 PM   #19
Sam Lusco
Sam Lusco's Avatar
I know someone with a 200 for sale with only 4 or 5 runs on it.
Sam Lusco is offline   Reply With Quote
Old 05-08-2018, 09:57 PM   #20
Dan Fahey
Dan Fahey's Avatar
Coan makes good transmissions!
Liked them when they started business in the early 80s.
The Metric 200 is fine for a lighter car.
4000lb plus weight you need a wider clutch and HD internals.
D
