Old 09-17-2018, 09:04 PM   #11
FED 387
Liked 332 Times in 180 Posts
Default Re: Hercules 225/75r15 12 Ply
Federal industry wide ratings any tire with a ST rating is rated for a maximum speed rating of 65 MPH at the proper inflation.
Old 09-18-2018, 09:11 PM   #12
NSSGTO
NSSGTO's Avatar
Liked 24 Times in 17 Posts
Not all are rated at 65mph. Some of the ST tires are speed rated "L" at 75MPH. The Hercules H-901 225/75/15 is Load Range F and Speed Rated L (75MPH)
NSSGTO is offline   Reply With Quote
Old 11-10-2018, 04:14 PM   #13
NSSGTO
NSSGTO's Avatar
Giving this a little bump as I will be swapping out my 2 year old Westlakes around Feb 19. Anyone else running these yet?
Old 11-19-2018, 08:22 AM   #14
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Originally Posted by lareagle View Post
Has anyone ever used a heavy ply truck tire in place of the trailer tires ?
Tire dealer said the speed rating is about 65 mph on trailer tire and were
running right on edge that could make to much heat on tire.
Larry
I recently switched to 10 ply truck tires after having blow outs with 10 ply trailer tires.
The trailer pulls so much better now.
I had to go to 16 inch wheels to use the LT225-75-16 Truck tires.
LT truck tires are the way to go, IMO.
Anyways, my trailer uses 5 lug 4 1/2" bolt pattern.
I was amazed to only find one wheel company that made a 16 inch- 5 lug 4 1/2 inch bolt pattern wheel in steel.
Old 11-21-2018, 10:45 PM   #15
copo69
Where did you find the 16 inch wheels with the 5x4.5 bolt pattern?
copo69 is offline   Reply With Quote
Old 09-30-2019, 03:38 PM   #16
Glenn Briglio
Glenn Briglio's Avatar
Liked 970 Times in 308 Posts
Any updates from using these Hercules trailer tires 15"
Old 10-20-2019, 10:40 PM   #17
NSSGTO
NSSGTO's Avatar
I have been running these all year. Only have around 5-6K on them but so far so good. They really track better than any other trailer tire I have used.
I run around 90PSI in them, They are on a 28FT ATC with 3500lb car, golf cart, tools etc weighing in around 9800.
