Old 02-16-2018, 11:17 PM   #11
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Default Re: Groove In BBC Lifter Bore
Carl, you have to allow for the fact that the angle of the lifter bore is also off in the old blocks. That does effect the valve event timing regardless of the lifter type.
Old 02-17-2018, 07:36 AM   #12
carl hinkson
Liked 18 Times in 10 Posts
It would have to be off 5 degrees to have any effect and I have not seen any that far off.
Do machine lifter bores ???
carl hinkson is offline   Reply With Quote
Old 02-18-2018, 06:54 PM   #13
Liked 1,953 Times in 439 Posts
Originally Posted by brian schuetta View Post
What are your thoughts on cutting a vertical groove in a BBC lifter bore for flat tappet cam lifters?
I never do it. I consider it a crutch, at best, which does not actuallysolve any problem, at best it might mask a symptom.
